I updated my SVCD2DVD about 3 weeks ago from version 2.1 to 2.5, and it also updated my .Net Framework with version 2.0. Since then, my computer no longer turns itself off when the movie is done. Instead, it just log off the computer and stay there. My computer has the Window XP with SP1.
Any helps will be greatly appreciated!
I'm having the exact same problem. Selecting "Shutdown When Finished" merely logs me off. It does not shutdown the the computer. Also selected "Force" and this appears to do the same thing.
ChrissyBoy,
Can you have a look at your SVCD2DVD program to see why it only lock off the computer when it is done? I also selected "Force"and used the newest version, but it is still the same. My CloneDvd & WinAvI programs still turn itself off the computer when they are done. It happens on my two computers. Thanks for your help. -
I have fixed this for the next release.
Computer random turn on
By WinSpecToR in forum ComputerReplies: 10Last Post: 31st Jan 2012, 15:09 -
HELP with some computer problem,won't turn on??
By demolitionman1985 in forum ComputerReplies: 6Last Post: 8th Sep 2008, 12:35 -
SVCD2DVD doesnt turn off computer when it is done.
By simhel in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 21st May 2008, 11:11 -
New Computer Screen Won't turn On, and CPU Doesn't Respond Either
By kerrex_2006 in forum Newbie / General discussionsReplies: 16Last Post: 22nd Nov 2007, 05:25 -
Help: Computer wont turn on!
By NateDizzle in forum ComputerReplies: 12Last Post: 20th Nov 2007, 13:10
