I replaced my directv receiver box. Now, when I record to dvd from my new box I have no closed captioning on playback. I had cc when I played back a dvd recording made from my old receiver. Can anyone explain this?
Yeah, your new DirecTV receiver doesn't appear to be CC capable. Or, more likely, it doesn't write the CC data to the DVD. Since CC is a requirement for US broadcast equipment, do the CCs display when watching live TV? You might want to carefully word a letter of disappointment and send it to DirecTV.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Hi:
Don't know a thing about DirecTV. But the DVD must be
interlaced; top field first. CC uses line 21 of the top field to store the CC info.
So if that receiver should deinterlace and/or reverse the fields you won't get CC.
Also if it crops the image, no CC. If you can drag one of the VOB's into Gspot,
that will show if it is interlaced and TFF. Good luck.
hunter99The Second Amendment:
AMERICA'S ORIGINAL
HOMELAND SECURITY -
Also, try setting the resolution on the DirecTV box to something other than "Native", and/or test with a 720p or lesser video stream.
I have confirmed that when using this setting, with a 1080i broadcast, the S-Video-out stream no longer contains Closed Captions. They do in all cases come thru the HDMI for TV display.
Don't know how this will affect the firewire capture, but it might be a factor.
Closed Captioning in Europe
By Headway in forum DVD & Blu-ray PlayersReplies: 12Last Post: 5th May 2010, 09:10 -
Problem with Bluray drive and closed captioning.
By impmon2 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Apr 2010, 12:10 -
Hardcoding closed captioning as subtitles?
By merciscool in forum MacReplies: 0Last Post: 28th Jan 2010, 05:12 -
no vhs closed captioning
By marvinwc in forum Newbie / General discussionsReplies: 8Last Post: 16th Oct 2009, 18:32 -
TMPGEnc Has a Problem with Closed Captioning
By jeanpave in forum Authoring (DVD)Replies: 10Last Post: 30th Apr 2009, 17:02
