I was wondering if anyone had the same problem I have using DVD Moviefactory 6. What happened is I purchased the latest version of MF6 Plus and after installation I opened the software and inserted a small movie file. I went past the first step which is adding chapters and video editing, then I proceeded to step 2 which is menu selection.
Menu selection went fine now I was ready for step 3 which is burning the disk, this is where the problem starts. I was unable to proceed to this last step. Nothing happened, the program stays on step 2 (the menu screen) and was unable to advance to step 3.
I went to the Corel/Ulead Disscussion forum and found that others are experiencing the same issue. I also noticed that there seems to be no remedy for this issue. I was wondering if anyone has the same problem, if so what did you do to fix this problem.
Here goes a link to someone who also has this issue: http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16832106057
I want to add that I am using Vista Preimum.
Results 1 to 1 of 1
Do unto others....with a vengeance!
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 15:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 20:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 10:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 08:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 21:34
