I wonder if anyone can help, I'm getting rather confused trying to sort this out
I have an AVI file (mpeg4 codec) that has no date/time stream. I want to display a date/time (of my choosing) when viewing the file.
is there any way to create a date/time avi stream? I don't have a DV camera to create a file to steal it's stream unfortunately.
an alternative would be to merge/overlay two AVI files (the second being a black screen with date/time displayed on it in white text-captured from my ancient anologue camera) it looks possible but the script instructions were a little cryptic-
could anyone show me an example script?
thanks
ken
	sorry to sound daft.....i'm very new to using scripts........
 could you show me an example script? I'm not sure how to decide how to fill in all of the variables (eg font, angle, colour etc) which ones are numbers, and which are words?
 what do you think about the overlay idea?
 cheers
	Write the following text in a Notepad window:
 , save as "BlankClipSMTP-test.avs", open this latter in VirtualDub, play it.BlankClip(fps=25, length=1500, width=640, height=480)
 KillAudio
 ShowSMPTE(offset="00:00:15:00", x=520, y=448, font="Lucida Console", \
 size=20, text_color=$ffff00)
 Change the parameters in Notepad, re-save, press F2 in VirtualDub, re-play.
 Repeat the process until you're happy with the results.
 Good-luck (and much patience as well).
 P.S.: Remember to have Avisynth installed on your computer,
 first of all!
	thanks-I'll have a try when I get back home, just a few Q's...
 where does the script generate the date and time from?
 what does $ffff00 mean for "colour" and do you know the codes for other colours?
 Do you think the overlay thing is possible as that would give the result i'm looking for (ie the date and time in the same position/clour as the other vids) I just need to know how to set the black background to transparent and the white numbers to opaque and then overlay this over the original image?
	ah yes, I need the date too............that wouldn't come with the SMTP timecode would it?
 more complicated than I thought!
 cheers
	While the clip is running:where does the script generate the date and time from?
 (frame_index_# + 1) ÷ (framerate) = elapsed_time
 $RRedGGreenBBlue is equivalent to the hex triplet used in HTML (#000000 = black, #FFFFFF = white, #c0c0c0 = silver, etc.)what does $ffff00 mean for "colour" and do you know the codes for other colours?
 No --- you will have to use the resource "Subtitle" in Avisynth to display the date along your video.ah yes, I need the date too............that wouldn't come with the SMTP timecode would it?
 Unfortunately I nearly have no experience at using overlays (I used Avisynth's Overlay
 only once, for creating an "infamous" scanline effect ). If I were you, or if you ). If I were you, or if you
 were me, whatever, I'd call the source .avi via Avisynth, add the commands ShowTime
 to display the timecode and Subtitle to display the date, and re-encode as a new .avi
 (with VirtualDub) or as a new .mpg (with HCenc or something). Anyway, you'd better take
 some time to read the Avisynth documentation and start practicing the art of encoding
 video. I myself still have much to learn, before November of 2006 I still was a complete n00b,
 but I am not ashamed to share the very little I have managed to learn so far.
 Ganbatte! ^_^
	To whom this may interest... 8)
 generated with Avisynth's ShowSMPTE and VSFilter's TextSub.
 monica_veloso-preview.m1v
  date/time stamp on AVCHD possible?By Mike82 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 17th Aug 2014, 18:26
  Overlay Time & Date Code On MPEG-2 FileBy minko in forum Video ConversionReplies: 32Last Post: 31st Jul 2011, 19:35
  Sony Bloggie Date Time Stamp Data Code Imprint Overlay MP4 VideoBy surfandride in forum EditingReplies: 4Last Post: 30th Apr 2011, 09:03
  Time/dateBy whitek75 in forum EditingReplies: 3Last Post: 10th Mar 2011, 12:50
  Date & TimeBy fzf5bl in forum MacReplies: 1Last Post: 8th Nov 2007, 03:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
