Hi all!
I need a commandline tool for turning a stillpicture and a soundfile into a backround.vob to use with dvdauthor when producing a video-dvd. Anyone know of such a creature?![]()
https://forum.videohelp.com/topic338311.html will get you an mpeg elementary or programme stream, which is most of the way there. You should be able to use DVD Author or Muxman from the command line to turn this into a VOB.
Read my blog here.
I use Mpeg Video Wizard DVD to do this. You can import sound and make a JPEG clip, by copy and paste, as long as sound file to produce menu.
Or if you use DVD Lab for authoring it will automatically create menu from still picture that last as long as sound.
add background music using ffMpeg or any commandline tool (free)
By Shohag_ifas in forum AudioReplies: 2Last Post: 21st Jan 2011, 06:25 -
How do i AVS > WMV - the commandline way
By squadjot in forum Video ConversionReplies: 4Last Post: 27th Apr 2009, 07:59 -
Any easy tool to make a DVD photos slideshow with the background?
By coody in forum Authoring (DVD)Replies: 9Last Post: 27th Sep 2008, 14:34 -
what ffmpeg commandline should I use ?
By halsboss in forum Video ConversionReplies: 2Last Post: 3rd Apr 2008, 04:49 -
VOB2MPG from a commandline?
By YoKnows in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 9th Jul 2007, 08:57
