    May 2007
    Australia
    This is what I want to do
    I currently use Tmpgenc to author a dvd of australian idol performances in order as per each show
    Easily done ........
    But what I also want to include on the dvd is a menu that will play each artist .... i don't want to have to include the same file as I have already included them in the episode menu
    Is there a way to include a menu that references the already incuded files per singer?
    Apr 2004
    Miskatonic U
    You need an authoring tool that supports playlists. DVD Lab Pro is one that can do this. You would put all your clips into a single title, as normal. You would then add chapter points at the start of each clip. Finally, you create a Chapter Playlist per artist that contains only chapters with that artist's performance.
    Read my blog here.
