I switched my display settings/monitor/advanced from pc to tv monitor because my tv is an hd with a montor plug in the back and thought I had to do that in order to hook it up, well no, wrong, so I went and hooked it back up to my monitor and after boot cant see any thing unless I go in safe mode/VGA,Network, or reg and the the display won't show the advance tab for switching back to pc monitor in any of the safe modes, any one have an answer? HELP!
Samiam5156
Press F5 or F8 (I forget which) during bootup. You will get the option to boot using "last known good config". That should be a config before you made the changes.
You could also boot into Safe mode and try changing video drivers (generic driver will work fine) or uninstalling the video drivers. Then after it reboots, you should have default settings and you can reinstall the latest video drivers.Google is your Friend
Sony DVD recorder switches off, but won't switch back on
By Weem in forum DVD & Blu-ray RecordersReplies: 5Last Post: 2nd Jan 2012, 18:34 -
2-way splitter or A-B switch?
By CSULB71 in forum DVB / IPTVReplies: 4Last Post: 29th Dec 2010, 09:50 -
How to switch FFDSHOW back on.
By eldobkram in forum Newbie / General discussionsReplies: 3Last Post: 4th Dec 2009, 14:37 -
No joy from Joytech! HDMI Selctor Switch problem.
By Sproggins in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Aug 2009, 07:02 -
APEX AD1250X stuck in PAL mode cant switch back
By sysman0 in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 23:04
