i have no problem getting dvd and cd covers. i just don't know how to resize them on the computer so they are the same size at the case. i need a standered dvd cover and a slimline jewel case template. where can i get these form? can anyone help? thanks
Follow this link....
http://www.coverxp.com/main.asp
Download CoverXP - it uses templates to resize covers to fit all types of case including VHS/CD/DVD/Slim DVD etc
And it's FREEDon't worry.......we'll be alright... -
Most printing tools allow you to create your own templates (CoverXP included), all you really need to look for is the dimensions of the covers you are trying to create.
Google is your Friend -
MultiCoverPrint
http://multicoverprint.en.softonic.com/
Print CD, DVD and VHS covers at the exact size.
I've been using this freebie for YEARS...only I design
my own or copy the ones I already own. -
Not all cases are the same anyway. Pull out a ruler and measure. Use the rulers in the image software. Make them match. Easy as that.
Templates not required, and often not desired.Want my help? Ask here! (not via PM!)
I'm confused, the site only lists the Windows programOriginally Posted by hech54
beefer -
Beefer since the OP has a Windows XP machine he was offered a Windows software solution.
You might have better luck asking this question over in the mac sections.
Good luck
DVD Covers - What Paper?
By Nitro89 in forum MediaReplies: 12Last Post: 15th Apr 2009, 18:02 -
DVD covers
By Seasonal in forum Off topicReplies: 3Last Post: 3rd Mar 2008, 18:30 -
looking for dvd movie covers
By fonzbear2000 in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2007, 22:35 -
DVD Covers
By Beefer in forum MacReplies: 7Last Post: 15th Nov 2007, 14:17 -
HQ DVD Covers Before There Release
By twiggy99 in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2007, 14:01
