I am looking to get an entry level HD DVD player which means one that is on the cheaper end of the spectrum. I will be using it to view some hd dvd's and to do some testing so I don't need anything fancy. I do need it to be able to play standard avi as well as upconvert standard dvd's. Any recommendations?
Results 1 to 10 of 10
Well no HD player supports raw avi's or MPEG files at the moment but a good entry level player is the Sony PS3(Blu Ray) or the MS XBox 360(HD DVD).The cheapest option is the Toshiba A2/A3 HD DVD player but I recommend the A20/A30 because it has a better upscaler.
I don't think any of them play AVI files. All HD DVD players upconvert standard DVD's.
The entry level units are the Toshiba HD-A1 (1st generation), the Toshiba HD-A2 (2nd generation) and the Toshiba HD-A3 (3rd generation).
Target has a Venturer HD DVD player, but it costs only a little less than the HD-A2 or HD-A3 at this time.
I have an HD-A2 and it is excellent, a great deal for the money. The A3 is basically a newer version of the A2.
I also have an HD-A20. It has better standard DVD upconversion quality, plus can do 1080p/24 native output. -
I guess what I meant by avi was divx/xvid support. Do any of the hd players support this playback?
Not at this time.
If you want Divx support, you will need a 2nd player.Google is your Friend -
There are ZERO HD-DVD players that play anything except HD-DVD, DVD and CD audio. No VCD support. No SVCD support. No Divx support. No file play support. A few might maybe play MP3 - not sure. I know that none of them will play VCD, SVCD, Divx and raw MPEG/VOBs.
The cheapest HD-DVD player only has 1080i video output at this time. If you want 1080p output, you will pay for it. I don't think anything that costs under $400 at this time supports 1080p. -
Stick with Standard DVD for now. Wait until the HD domain developes.
I've got three players and a three port HDMI switcher. A Toshiba HD-A20, a Samsung BD-P1200 and an Oppo DV-980H. So, I'm totally covered for virtually any type of disc, even for high resolution SACD and DVD-Audio.
The HD-A20 is a $219 refurb, the BD-P1200 was new but a really great eBay deal, and the Oppo was purchased new from them. With the HDMI switcher and cables I've got about $800 into the three player setup.
I mostly rent HD DVD and Blu-ray discs from Netflix. Haven't bought a standard definition DVD in months. Barely watch SD DVD anymore, except for my kids' videos.
BTW, I started out small with a used (and very cheap) HD-A1. Once I got a close look at high def discs on my display, there was no turning back! I had to go format neutral. -
That's all any home theater lover can do at this point is get multiple players. If you are serious about HD home theater you need an HD-DVD and a Blu-Ray player. Plus there are many of us here that also want/need Divx support, so that is a third player.Originally Posted by gshelley61Google is your Friend
DVD Player brand recommendation
By majax79 in forum DVD & Blu-ray PlayersReplies: 21Last Post: 26th Nov 2010, 21:51 -
Stand-Alone DVD Player recommendation
By -mm- in forum DVD & Blu-ray PlayersReplies: 24Last Post: 2nd May 2008, 12:13 -
dvd player recommendation
By bagrol1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 21:25 -
By tomchook in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jul 2007, 09:01 -
DVD Player recommendation needed (UK)
By johnyccc in forum DVD & Blu-ray PlayersReplies: 5Last Post: 9th May 2007, 21:06
