I'm trying to capture using Virtualdub in my account under XP Pro, but want to be able to let my kids log into their accounts to using XP's user switching. However whenever I try to switch users, the capture stops.
Is there any way to prevent this?
thanks,
Kevin
If Virtualdub is using DirectShow for the capture and there is a window showing what is being captured then this can happen. It's a Microsoft thing.
Can you reproduce the problem just by pressing Ctrl-Atl-Del and then going back to where you were? If so, it almost certainly is the same issue we have had to program around in one of our programs.
For some reason, when the video mode changes and there is a window showing the video, DirectShow restarts what ever it was doing. Specifically, it happens when the program is using the "Video Mixing Renderer" for the video window.
I don't know enough about VirtualDub to know if you can change it to use a different renderer for the video (that's what our program does). If VirtualDub is relying on the DirectShow subsystem to provide the renderer filter automatically, then the only way around it is to unregister the "VMR9" filter from the system.
Perhaps someone more familiar with the inner workings of VirtualDub can confirm/deny my suspicions. -
http://support.microsoft.com/kb/279765
Video capture , even if it was to work via this method , would still have issues .
Video rendering and similar work loads under this condition , no problem .
Considering the system specs listed ... do not do it .
PotPlayer: no audio switching, no subtitle switching
By Anonymous9843 in forum Software PlayingReplies: 1Last Post: 6th Oct 2012, 21:44 -
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 23:17 -
Playback with MPCHC while still capturing stops at old end of file
By suppa in forum Capturing and VCRReplies: 0Last Post: 30th Dec 2009, 14:11 -
Capturing stops when 'Source' button on monitor is pressed...
By montageman in forum Capturing and VCRReplies: 3Last Post: 24th Oct 2009, 22:54 -
Sounds stops capturing after ~7 minutes every time
By rmcc4444 in forum Capturing and VCRReplies: 5Last Post: 13th Apr 2009, 12:18
