Hi everyone, I wanted to know for the sake of a friend that if the RH7521W is able to record HD playback.
Here in Australia we've got numerous channels that have HD (upwards to 1080i) material broadcasting prime time shows. I'd like to know if its possible with the input of a HD set top box to record such things. I'm new to this sort of thing, but however I don't see anything relating to digital formats that it can record on the LG website itself.
If it is possible, would the RH7521W retain the HD quality that it streamed with ?
Thanks for the support.
Ciao.
At this time you MUST buy a BluRay recorder if you want to record HD signals in HD. While a regular DVD recorder can technically record an HD signal, it will do so in standard definition and you will lose all the benefits of HD (resolution and high bit rate).
No, it will not. That model only records SD format, not HD. You could record/save HD content using an HD-DVR. But that would be HDD based and not DVD based. There are currently no DVD recorders that support HD.
As noted by jman98 above, there are new Blu-Ray recorders for this purpose, but I believe they are only available in Japan.Google is your Friend
Help w/ playback issues on blu-ray player of dvr recording
By bgart13 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jan 2011, 00:54 -
By bgart13 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2011, 23:02 -
Recording with audio playback
By waefwaeefwaefw in forum Capturing and VCRReplies: 2Last Post: 13th Nov 2008, 10:31 -
DVD recording and playback
By Special T in forum Newbie / General discussionsReplies: 1Last Post: 5th Jun 2008, 09:15 -
Pioneer DVR 630 HS - Recording will not playback
By ktmsprocket in forum DVD & Blu-ray RecordersReplies: 3Last Post: 14th May 2008, 13:06
