Hello all, I just got turned onto DVD-RB, I have been using DVD Shrink for the longest time. I have desided that I want better quality backups from DVD-9 to DVD-5. I use RipIt4Me to rip movie only, and DVD Shrink to take out extra audio and sub's.
Now I would like to use CCE2 with DVD-RB as my encoder/transcoder instead of DVD Shrink. From what I have read this is the best way to get the best quality.
OK, so is DVD-RB compatible with Vista? Hell is CCE2 compatible for Vista? If so can I use DVD-RB basic with CCE2.
In my search for a better way to do backups InterVideo DVD Copy 5 came up, and it is the only solution that I have found so far that is Vista compliant. I have used it, it works fast, as far as I can tell it makes good quality backups, although I have never seen first hand CCE, CCE SP, or CCE 2. I just wish that DVD Copy had more advanced options.
Does anyone else have any thoughts or opinions on InterVideo DVD Copy 5? What encoder does it use anyway? Is it any good?
Read my blog here.
Use DVDFAB DECRYPTER instead of RIPIT4ME since it's no longer updated.
DVD burning software compatible with vista
By toolady in forum ComputerReplies: 6Last Post: 9th Oct 2008, 14:06 -
Are any of these programs Vista compatible?
By magicfingers in forum DVD RippingReplies: 12Last Post: 7th Aug 2008, 19:04 -
Vista (DX10) compatible DVD player
By Dark Alpha in forum Software PlayingReplies: 1Last Post: 23rd Jun 2008, 18:19 -
Vista compatible?
By Anonymous4374945 in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 10:55 -
Vista compatible program?
By smudger2468 in forum Video ConversionReplies: 4Last Post: 31st May 2007, 16:09
