I have an old DVD player and it does play avi format. I am looking to buy new dvd player which support avi format.
The question I have is
1) Do I need to re-encode the avi files to make it work on dvd player
2) Is there any standard set for avi file which can be played on latest dvd players
Thank you
1. Maybe but if they are standard divx or xvid file they will probably work.
2. Only for DivX, visit http://www.divx.com/certification/ -
So as long as they are divx or xvid they will play regardless of video size, bit rate, etc...?
Thank you -
There are Divx and Xvid features that many players don't like -- but if your files played properly on your old player they probably didn't use any of those features and they will more than likely play on any new Divx/DVD player you get.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 08:25 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 20:32 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
