How total data rate of a encoded video is calculated? Is it simply the sum of video and audio data rates?
For example, I encoded a video clip into Flash Video using On2 VP6 codec. Following is the encoding details for this Flash Video file reported by the MediaInfo software tool. As you can see, the total data rate is shown as 222 Kbps, where as the sum of video (150 Kpbs) and audio (32 Kbps) data rates is only 182 Kbps. Why is the difference - 222 Kbps vs 182 Kbps?
----Encoding Info of Flash Video File by MediaInfo Tool--------
General #0
Complete name : Video Clip.swf
Format : Flash Video
File size : 4.50 MiB
PlayTime : 2mn 50s
Bit rate : 222 Kbps
Video #0
Codec : On2 VP6
PlayTime : 2mn 50s
Bit rate : 150 Kbps
Width : 320 pixels
Height : 256 pixels
Aspect ratio : 5/4
Frame rate : 29.970 fps
Bits/(Pixel*Frame) : 0.061
Audio #0
Codec : MPEG-1 Audio Layer 3
Bit rate : 32 Kbps
Channel(s) : 1 channel
Sampling rate : 22 KHz
Resolution : 16 bits
Video0 delay : 75ms
-----End------
Doesn't a swf include some extra stuff like a player or something? That's maybe why MediaInfo thinks that the total rate is so much bigger.
http://en.allexperts.com/q/Shockwave-Flash-1515/FLV-vs-SWF.htm
MPEG Streamclip "limit data rate" disabled
By Dignan. in forum Video ConversionReplies: 7Last Post: 23rd Nov 2011, 12:59 -
avi data rate too high?
By hello2000 in forum Video ConversionReplies: 5Last Post: 3rd Aug 2010, 10:43 -
How is .SUB timing calculated ?
By darconio in forum SubtitleReplies: 5Last Post: 12th Dec 2008, 08:26 -
Data rate for HD video
By spandau in forum EditingReplies: 3Last Post: 21st Nov 2007, 13:23 -
DivX to MPEG2 conversion - ideal data rate
By danniballoon in forum Video ConversionReplies: 3Last Post: 7th May 2007, 15:28
