Hi I see that this has been mentioned before but I have yet to see a fix for it and I thought that people might be asking the wrong questions or not giving the full symptoms.
Movies are very jerky.
I use Nero 7 for converting AVI to DVD. Small files are fine (350 MB to 700MB) but when the file is over 1 gig, the problem starts and the movie is jerky. Nero 7 automatically changes the file size to fit on the DVD and I assume that it is this that causes the problem. I do not change anything I just let Nero do its thing.
If it is played from the Nero player, just before you burn it is also jerky.
Is there any fix for this.
System: Self build bit old now but still fast ish.
AMD XP2600+
2.07 ghZ,1.50 gb ram
Many thanks
PS I have also noticed this problem with ConvertXtoDvd
	No, the source file size shouldn't matter at all. It must be something else like a frame rate issue like NTSC to PAL, PAL to NTSC, 24fps to 29.967 without pulldown or a video/audio decoding issue because the file size just tells you that the clip is either longer or has higher video/audio bitrate.
 Do the 350/700MB and 1GB avi files have the same video and audio codecs and frame rate? Post the details of your source files , identify with for example gspot.
 Are you converting to PAL or NTSC?
 Or try another all-in-one solution like FAVC or DVD Flick and see if you get same jerky playback.
 Or why not get a cheap divx/xvid player or build your own HTPC!
	Thanks for the quick reply. I will digest what you say , fiddle about a bit and report back later.
 Yes the cheep player would be an option. BVut I really want to sort this one out.
 Many thanks
  Avi to DVD ProblemsBy RBCC in forum Authoring (DVD)Replies: 6Last Post: 9th May 2011, 15:55
  NERO7 HELP ! Burning 2 files to 1 dvd5By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 12th Jun 2010, 02:13
  help sound syncing probs usig Nero7By polbol in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:19
  Date in label field in Nero7By colorbars in forum ComputerReplies: 0Last Post: 3rd Oct 2007, 04:34
  New Asus DRW-1814BLT Sata 18x Burning slowly Nero7By DAVE440 in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Sep 2007, 02:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
