Hi,
I would like to know how to make a SVCD with 2 audio tracks and a menu where I can select the language I want ?
I believe you'd need I-Author for that. It's no longer sold. That makes me wonder why it's not posted anywhere for download.
As far as the 2 audio tracks go...you could combine the two tracks into one. You can load the two tracks into a program like Acid and combine the two and spit out one audio track. Then encode and mulitplex with the video.
Thanks Gambit_32 but can you explain more precisely how does it work (When I want to watch my svcd, how can i choose the audio track i want, how does it work?)
Spax -
Hi!
Sorry to say this but I think you're leading Spax in the wrong direction guys!
If you want to put 2 stereo audio tracks on a SVCD all you have to do is :
1) compress your video and audio separately. This will leave you with one video (.m2v or similar) and 2 audio (.mp2 or .mpa)
2) Multiplex all three files in bbMPEG and you'll end up with an MPEG2 system stream that you can burn and which will allow you to switch between audio tracks.
I've used this technique on a few DVD rips to have both the main sound and also the commentary audio - works a treat!
One thing to note though is that, with 2 audio tracks, the file size will be a bit bigger than with 1 - sounds obvious I know but I just thought I'd mention it!!
Easy,
Sue xxx
Thanks a lot !
I still have a problem: i have multiplexed my video track and my two audio tracks but i can't choose the audio track i want in my player (i've tried with all the existing svcd player with no results !!
Can you help me please ?!!
Spax -
just choose left or right chanell on remote if it has it im assuming you hear both audio tracks at once???????? :-?
Here we go again .... !!!!
Let me clarify a little .......
There are TWO STEREO tracks allowed by the SVCD standard thereby giving you a Left 1 & Right 1 AND Left 2 & Right 2 - OK?
Therefore, once you've correctly muxed the 1 video and 2 stereo audio files together and burnt the resulting MPEG2 system stream, you'll should be able to choose between the TWO STEREO audio tracks on your player.
On my DV-444, pressing the AUDIO button on the remote allows me to toggle through these stages :
STEREO 1
Left 1
Right 1
STEREO 2
Left 2
Right 2
Which player have you got Spax, maybe we could help.
Speak soon,
Sue xxx
Need a free program to burn Music CDs and make all tracks the volume level
By Starry in forum AudioReplies: 5Last Post: 19th Mar 2011, 16:26 -
How to make dual mp3 tracks
By NotoriousGRK in forum AudioReplies: 3Last Post: 23rd Jan 2011, 19:21 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37
