Hi all,
I'm trying to author a DVD using DVDAuthorGUI but got an unknown error. I looked at the log & it seems to be something about a "frame data under-run". Could someone please explain me what causes this & , more important, how to fix it?
Thanks in advance,
ChibiTomo.
Details:
- m2v was created with HC v0.21. Made sure everything was DVD compliant. NTSC Source.
- ac3 taken directly from original DVD using DGMPGDec. 0ms delay, verified with media player classic.
- Authoring as NTSC with 1 title, 3 menus, 12 chapters & a srt subtitle file.
- After the error the output folder only contains Title1.mpg. Which plays in mpc without subs, menu or chapters. (only video, sound - in sync)
- let me know if you need more info.
DVDAuthorGUI 1.014 - 7/10/2007
Send problems with DVDAuthorGUI to liquid_217@hotmail.com
***please wait while the titles are multiplexed.
*multiplexing title: 1.....
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File C:\Documents and Settings\...\Title1.m2v looks like an MPEG Video stream.
INFO: [???] File C:\Documents and Settings\...\Title1 T01 3_2ch 448Kbps DELAY 0ms.ac3 looks like an AC3 Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (C:\...\Title1.m2v)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 720
INFO: [???] Frame height : 480
INFO: [???] Aspect ratio : 16:9 display
INFO: [???] Picture rate : 29.970 frames/sec
INFO: [???] Bit rate : 8000000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: AC3 Audio stream 00 (C:\...\Title1 T01 3_2ch 448Kbps DELAY 0ms.ac3)
INFO: [???] AC3 frame size = 1792
INFO: [???] AC3 AUDIO STREAM:
INFO: [???] Bit rate : 57344 bytes/sec (448 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 8633400
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio bd: buf= 16384 frame=000000 sector=00000000
++ WARN: [???] Stream e0: data will arrive too late sent(SCR)=447057627 required(DTS)=0
++ WARN: [???] Video e0: buf= 192728 frame=148866 sector=02006669
++ WARN: [???] Audio bd: buf= 4291 frame=155229 sector=00137982
INFO: [???] Scanned to end AU 156695
INFO: [???] STREAM e0 completed @ frame 156695.
INFO: [???] STREAM bd completed @ frame 163372.
INFO: [???] Multiplex completion at SCR=470504594.
INFO: [???] Video e0: buf= 190264 frame=156695 sector=02105412
INFO: [???] Audio bd: buf= 2048 frame=163372 sector=00145221
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 4251646410 bytes
INFO: [???] Sequence headers: 11682
INFO: [???] Sequence ends : 1
INFO: [???] No. Pictures : 156695
INFO: [???] No. Groups : 11682
INFO: [???] No. I Frames : 11682 avg. size 61431 bytes
INFO: [???] No. P Frames : 50905 avg. size 38087 bytes
INFO: [???] No. B Frames : 94109 avg. size 16949 bytes
INFO: [???] Average bit-rate : 6505200 bits/sec
INFO: [???] Peak bit-rate : 8037200 bits/sec
INFO: [???] BUFFERING min 15 Buf max 235543
INFO: [???] AUDIO_STATISTICS: bd
INFO: [???] Audio stream length 292764416 bytes.
INFO: [???] Frames : 3029013119
INFO: [???] BUFFERING min 35 Buf max 10339
**ERROR: [???] MUX STATUS: Frame data under-runs detected!
Process aborted due to above error
There was an unknown error. Please review the log for more information.
"It's like a finger pointing a way to the moon; don't concentrate on the finger or you will miss all that heavenly glory" Bruce Lee, ETD.
You may be able to just ignore the error using that option under 'file' (ignore errors while authoring). Mplex appears to be saying that the combined AV stream is too high, and is therefore warning you of data underruns.
You might also try using the alternative muxing tool, which can be enabled under 'tools'. -
liquid217,
Using the ignore option seems to work. The DVD plays fine on my standalone.
Thank you."It's like a finger pointing a way to the moon; don't concentrate on the finger or you will miss all that heavenly glory" Bruce Lee, ETD.
Premiere Pro 'Error Compiling Movie - Unknown error'
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2012, 16:43 -
Error -1856: An Unknown error occured
By Tyler2000 in forum Software PlayingReplies: 2Last Post: 27th Oct 2010, 19:55 -
SOLVED - need a little help in evaluating log file (ffMpegX)
By psil in forum MacReplies: 1Last Post: 13th May 2009, 08:39 -
Convert X to DVD - preview blank (log included)
By seedybrick in forum Video ConversionReplies: 8Last Post: 3rd Jan 2008, 08:28 -
problems converting video with 3GP (error log included)
By Luke Vader in forum DVD RippingReplies: 0Last Post: 17th Dec 2007, 16:20
