Does the SSE build or the MMX build of ffdshow perform significantly better than the regular builds of it?
Do you have SSE or MMX instructions on your CPU? If not, they won't do anything. If you do have them and your OS and motherboard takes advantage of it, you might see some improvement, but that's just a guess.
Those instructions are fairly common with most newer CPUs.
Try running CPU-Z. It will tell you if your CPU has those capabilities. http://www.cpuid.com/cpuz.php
SSE optimized firefox build(s)
By deadrats in forum ComputerReplies: 12Last Post: 2nd Mar 2010, 20:55 -
1080 hd in a regular dvd
By luc13137 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 1st Mar 2010, 13:31 -
NAS or just regular external drives?
By sdsumike619 in forum ComputerReplies: 3Last Post: 4th Dec 2008, 06:56 -
hd on a regular dvd player... conversion help
By screwyluie in forum Video ConversionReplies: 8Last Post: 1st Dec 2007, 23:39
