I need to convert the DVD movie from the PAL into NTSC color system. What ripper software do you recommend?
as many on here will echo-why do you need to do this?
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
It's not the ripping software that converts it from PAL to NTSC (or NTSC to PAL), it's a long and complicated conversion process that does that.
Ripping can remove the Region Code. For that try DVDFab HD Decrypter."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
The process for converting a full DVD, with menus etc intact, is complex, You have to
1. Rip the disc as PAL to your HDD
2. Demux all the audio and video elements, menu stills, subpictures, subtitles etc.
3. Convert each element, including re-encoding, fixing timings, converting image resolutions etc
4. Reassemble all the pieces back into the original structure and create new IFO files to reflect the changes.
If you do any of these steps badly, you screw the whole project.
Regardless of what some may try to tell you, there is no simple way to do this and produce a quality outcome. If you want it done right, it will be time consuming.
It is much simpler and cheaper (unless you normally get paid $300/hour) to just buy a multi-format player.Read my blog here.
There is no such thing....Originally Posted by coody
when you rip a dvd it is basically a bit for bit copy... if you want to convert a PAL format video to NTSC, you must demux the video & audio then convert the video & use DGPulldown to change the framerate, well, not actually but.... i'm not going to go into detail but start here....
The search function is our friend!!!!!!
https://forum.videohelp.com/topic300144.html?highlight=pal%20ntsc
Can VCL software convert NTSC to PAL?
By bobvideo in forum Newbie / General discussionsReplies: 5Last Post: 7th Nov 2011, 12:37 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Software Recommendations for converting 1080p HD clips to SD NTSC or PAL?
By seville63 in forum Video ConversionReplies: 2Last Post: 27th Mar 2010, 09:04 -
Need software that identifies PAL/NTSC
By djkilla in forum Software PlayingReplies: 5Last Post: 20th Jul 2008, 19:03 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
