.AJP is the extension on a video file I'm attempting to view. The file was made on a DVR hooked up to a security system. How do I convert the .AJP file into a Quicktime compatible video format? If the file can't be converted, is there any way to view the file on a Mac?
from filext.com:
Extension: AJP
AJP Player is the program required to play files that you backup to CD or DVD on older model JPEG2000 DVR's. ..... [Search for AJP file errors with this scan.]"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
The download is free, here: http://www.jpeg2000support.com/resources/AJPPlayer.exe
It's a DOS executable, so you'll need a PC or Virtual PC for the mac you use. It might run under Darwine.
The home site is here: http://www.jpeg2000support.com/ -
QEMU is free, but you'll still need Windows on top of it to work. The easiest way is to borrow a pc. Can you post a sample file for me to play with? Maybe I'll find something. You might try opening the file in a browser.
I used the AJPPlayer dnix71 recommended. I ran it through Virtual PC. It was as slow as one would expect in VPC, but it did the job (It even allowed me to save an AVI out of the security footage - very cool). Thanks for the help.
how to view old 3/4" video
By newsshari in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2011, 13:47 -
Video MetaData - How do i view this?
By jmadden93 in forum Video ConversionReplies: 1Last Post: 12th Jun 2010, 13:49 -
Video Partial View
By wonstep in forum Software PlayingReplies: 8Last Post: 29th Apr 2009, 22:04 -
Can't view video on VHS-C
By jbailey227 in forum MediaReplies: 3Last Post: 22nd Feb 2009, 18:35 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 00:01
