I might of found a hack for Samsung M301 but I don't have any Region 2 or 3 disk to try this out. Somebody please try this out.
Use Aiwa Remote hack (Do a cold start first). My Aiwa Remote was model RC-ZAS02. Pressing Sleep (Shift 8) will bring up following menu.
Completed Cold Start
DVD Single: NG
DVD Dual L0:NG
DVD Dual L1:NG
VCD/CD :NG
Pickup 2CD
CS: 01 1
Then press Shift+8+8 (Clock twice). This will eject the disk and ADJUST will be displayed on the dvd player.
Another interesting thing. If you press Sleep on your Aiwa remote while the dvd player is turned off it will illuminate your display panel with all the available function. One of them is PAL display which is not listed on the owner manual. Perhaps, there is a hack to play PAL disk on M301????
Hello,
I too have samsung dvd m301 player for my
home stero system.
My player is set for region 1.
I have region 2 disc I cant play.
Im not clear on your instructions.
I dont have aiwa remote, why is it needed?
If you can clarify your instructions a bit
I can perform the tests and maybe we'll have
the hack for 301, which I really want.
Tnx
new hack for samsung DVD-P181 needed
By indigogirl1200 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 9th Nov 2008, 19:58 -
Hack for Samsung DVD-1080P8 for region 1 ???
By juliette0406 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Jul 2008, 12:21 -
Computer DVD to be multiregional
By Elena9214 in forum Newbie / General discussionsReplies: 7Last Post: 28th Jun 2008, 16:04 -
Samsung DVD-1080P7 Region Hack
By adrian4321 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Apr 2008, 23:23 -
need a hack for SAMSUNG DVD-V9650
By alexey70 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Jun 2007, 09:22
