Would it be possible to put SD video on a HD DVD/Blu-ray? Because it would be nice to have a full season of 24 on a triple layer HD DVD or a dual layer Blu-ray disc.
Yes it would. In fact almost all the extras on a so-called high-definition movie release are still in standard definition. It would be especially useful for those older TV series where no HD release is possible. You still wouldn't get an entire series on one disc but they would at least fit in a single box. At present if you have even one faulty disc in a set you have to return the entire box to get a replacement. That is as big a hassle for us dealers as it is for our customers.Originally Posted by rowie4life
Not at this time. Neither standard supports DVD frames per second. Current DVD uses either 29.97 fps (NTSC) or 25 fps (PAL) and while both formats do (according to the specs) support DVD resolutions (720x480 NTSC and 720x576 PAL), both formats require frame rates of either 60 fps or 50 fps. So you'd have to find a good way to double your DVD frame rates and make it look OK. You'd still have to author the disc as either BluRay or HD-DVD. There's no way to burn standard DVD format to BluRay or HD-DVD discs just like you can't take a blank DVD-R and turn it into a giant SVCD disc.
Consumer burnable HD-DVD discs are theoretical at this time. As far as I know only BluRay actually has burners and blank discs available for consumers to use.
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 23:04 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 10:37 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
