Hi all appreciate help if it can be given.
I have a toshiba sd-370e player and it dont matter what i burn (divx files) and what speed i burn them at they tend to pause for a second maybe 2 during playback. Can anyone suggest what sort of cd media is best or burning software or is this a common problem? and if possible what is the best way to try and resolve it.
Burning software: Nero 6
current cd's:tdk though have tried others
Thanks .
Current setting on dvd player is 720p not sure if that makes a difference.
There are several possible causes. First thing you need to do is download Gspot and analyze your Divx files. It depends on the chipset your DVD player uses for Divx playback and I do not know which chipset the Toshiba uses, but the following can be problems on some DVD players for Divx playback.
1) QPel (quarter pixel)
2) GMC (global motion compensation)
3) Packed bit stream
4) Resolutions greater than 720x576
5) Video bit rates higher than 2000 Kbps. If your audio is anything other than MP3 (AC3, DTS, LPCP), you may need a much lower video bit rate to get it to playback correctly. You may have to go as low as 1500 or even lower.
Taiyo Yuden and Verbatim are generally best for CD media. While it could be your media, most likely your problem is in 1-5 that I described above. Packed bit stream can be fixed without re-encoding via MPEGModifier. The other 4 require you to re-encode the file to get rid of the problem. -
just once some times twice a disk 1st one happens normally within the first 15 mins
DivX vs. H.264. vs. Divx HD: What best for playback on Philips BDP5320 ???
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 26Last Post: 21st Sep 2011, 04:50 -
.MTS file sequential playback pauses between files
By Davecom4.6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 10th Jun 2009, 22:53 -
Philips DVDR3320V/37 - No DivX playback?
By NotSoEasy in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Dec 2008, 17:40 -
Pauses between the chapters during playback
By roblobster in forum Authoring (DVD)Replies: 8Last Post: 8th Feb 2008, 22:54 -
DivX can't playback some videos
By cheerful in forum Newbie / General discussionsReplies: 8Last Post: 20th Dec 2007, 12:36
