I'm finally able to make an mpeg 1 from an avi using tmpgenc through this forums guide when I try to burn it to a cd using nere 5.5 it gives no messages (finally) when its done with the burn process I put it in my dvd
player and it tells me no disc and I tell my dvd player this (@#$^%$#%$)
im using nero 5.5 tmpegenc 2.02 the dvd player is sony ns300 and the regional is ntsc any help is greatly apreciated
The cd you are making may not be a coaster. If you followed the instructions on this site. The no disc that your dvd player says means it can't read the disc. I would try copying your cdr to a cdrw not all dvd players can read cdr discs. Sony brand dvd players can be fussy reading cd's. Check this site to the left under dvd compatibility to see what your dvd player is capable of playing. If it is supposed to read cdr try an audio cdr disc if this works then it's possible it doesn't like the brand of cdr you used for the vcd try a different brand of cdr. I had a Sony 560 model and it wouldn't read cdr, it would however read cdrw but was still really fussy. Sometimes the vcd that I burned to cdrw would work sometimes the same cdrw wouldn't. I finally got sick of messing with my dvd player and went out and bought a cheap APEX DVD player it plays cdr,cdrw,vcd,svcd,mp3 discs I haven't had any problems. Sony DVD players play DVD discs well but can be really frustrating trying to get a vcd/svcd to play in them unfortunately. They say they will play them but they mean the stamped out kind of vcds with the silver backs not the burned vcd's.
toneytgr,
Look in this web site at:
http://www.vcdhelp.com/dvdplayers.php?DVDname=sony+&Search=Search&list=0
Some Sony DVD models not read CD-R and/or CD-RW.
Sorry, but there's nothing about your model (Sony ns300).
Bye -
It probably doesn't like your disk medium, as mentioned above. Also, I've read that Nero will intentionally (and silently) make coasters if you're using a serial number that's been published. It'll work on one version but not on the next upgrade.
Imgburn keeps making me more expensive coasters
By jbitakis in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jan 2012, 12:32 -
Making alot of Bluray coasters
By bpstyxman in forum Authoring (Blu-ray)Replies: 6Last Post: 13th May 2009, 02:09 -
Making some expensive DL coasters (Help!)
By nchd in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2009, 12:50 -
Roxio 8 misunderestimates DVD capacity? making lotsa coasters...
By ahhaa in forum ComputerReplies: 8Last Post: 7th Sep 2008, 18:57 -
Getting coasters with Nero 7???
By dagerousdave in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 19:12
