  1. Member pchan's Avatar
    Mar 2003
    Singapore
    I would like to use Mixpad to mix music of 60 minutes long with a conversation mp3 file of 5 minutes. I need the conversation will repeat itself for entire 60 minutes and able playback so that I can adjust the volume before I export the mixed audio. Can Mixpad do it ? Thanks.
    Apr 2004
    Miskatonic U
    Don't know MixPad, however Acid Express should be able to do it. http://www.sonycreativesoftware.com/download/step2.asp?DID=551
    Read my blog here.
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    @guns1inger,
    I posted the same querry to the WavePad support forum but there is no reply. It's likely that it couldn't do what I want. Will go for Acid. Older version works the same ?
    Apr 2004
    Miskatonic U
    Should do. Acid Express is a freebie, but if you have the full version, even if it's older, it will do what you need.
    Read my blog here.
  5. Member pchan's Avatar
    Mar 2003
    Singapore
    @guns1inger,
    Thanks. I take a look at the manual and it has many more features.
  6. Member pchan's Avatar
    Mar 2003
    Singapore
    @ guns1inger,
    ACID Xpress cannot output MP3 at 192 kbps. The WavePad forum has replied me that it can do the job. I am waiting for them to reply on my question whether it can output 192 kbps. Once confirm, I will buy it. By the way, this software maker is from Aussie.
    Apr 2004
    Miskatonic U
    Install LAME MP3 and Acid should be able to use it to encode MP3 at anything up to 320 kbps.
    Read my blog here.
