ok, I have a tub of 8.5gb DL DVD's and want to use some to make a few compilation discs of 2 or more DVD's.
I've already done a 3 film compilation of three feature films with no problems at all. Menu is fine and all films play fine and quality-wise are as good as the source.
what i'm trying to do now is create a compilation disc of 3 stand up comedy dvd's i have.
what i've been doing is ripping each disc to my hard drive using DVD Fab under wine, then running each one through avidemux.
I use the DVD(mpeg2enc) container and lower the default bitrate from 9000 to 7000. I use the AC3(lavc) audio container and leave the audio bitrate at whatever it's set at.
I set the format to MPEG-PS (A+V) and save the MPEG file. That in itself works fine. I then use DeVeDe to reduce the bitrate of the file even further so it gets to around 2.7gb for each file, which will allow me to fit 3 onto an 8.5gb disc.
The problem I then get is that on each stand-up DVD, whenever the comedian moves his arms or legs there is a "wobble" when played back on my PAL television.
As an experiment, i used K9Copy to create an MPEG4 file from each disk, then added them to qdvdauthor and used the transcode option to increase the frame rate from 25 to 29.97 and this corrected the "wobble".
it produced two other problems though - when I was watching one of the routines, the timer on my DVD was frozen at the first chapter mark - the video was playing fine, with no wobble and sound in sync, but the timer wasn't advancing.
on one of the other videos, the sound was in sync, but speeded up so the comedian sounded like a smurf
if i use avidemux and run a 2-pass conversion to get a 2.7gb output file, that also does work but then the sound is out of sync, and try as I might, I can never seem to correct it even by running it through avidemux loads of times and trying different numbers on the "shift" option.
so i don't know .. i'm stuck. I'm a linux newbie of a few months anyway, and i'm even more of a newbie at this level of video conversion - everything i've done so far has literally been trial and error and learning from my mistakes.
in a nutshell, what i need to do is rip the dvd, convert it to a 2.7gb MPEG file that has sound correctly synced and the correct framerate to play on a PAL television.
That's not that hard is it ?
any help would be very, very gratefully received as i've been trying to do this for about a week now with no luck, and i've posted this question on 4 different forums and nobody has yet answered.
thanks !!
Not sure if your source IS pal, but take a look at this,
http://www.linuxquestions.org/linux/answers/Applications_GUI_Multimedia/DVD9_to_DVD5_guide"The software said Win XP or better, so I Installed Linux" -
Hello,
Are you sure you are getting good rips on your original source DVD's? After they are ripped are they playing back properly with Avidemux? I find it is REALLY picky about it's MPEG-2 sources. Also you are really deteriorating your quality by transcoding your source so many times, Won't DeVeDe accept your original Rips and transcode them to 2.7Gb, it is using ffmpeg like Avidemux, it should do it directly. Another thing you could try is either running DVDShrink with Wine or the Linux equivalent which I think is called XDvdShrink or something like that, and make a new compilation from your 3 original DVD's.
Combining VOB files from different sources to create a new compilation
By bluesmanuk in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2010, 15:24 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
DVD compilation.
By Benhermies in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2008, 12:46 -
Making compilation DVD?
By chronic777 in forum Authoring (DVD)Replies: 8Last Post: 19th Jul 2008, 13:19 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36
