  1. Im using avi2vcd encoding, wondering why it takes about 23 hours to encode 8287 frames seems very slow
  2. Maybe your system is getting very old...
    or you can try to use other programs.... like TMPGenc...
    Panasonic Mpeg encoder,... etc...
    these are all in the download tools section of this forum..
    as long as my boss thinks i make a lot of money, i will pretend to work hard ;)
  3. i have a dell 1.7 80gig hard drive 512sbram dvd+rw/cd+rw
    Ive tried those and all the other things you need followed step by step as soon as i chose the source unable to blah blah blah
    at least this way works but is so slow
  4. do you have 2 separate hard disks... yes: try to store the input on one disc, and the output file on the other disc..
    are you copying to regular VCD... What are your settings ..??
  5. hi yes i chose vcd nt something
  6. need more input.... you mean VCD NTSC....
  7. yes i printed out all in one guide divx to vcd mpeg
    tools virtualdub,tmpgenc,vcdeasy plus div3.11 and divx4
    i downloaded all tools installed both divxs
    then followed from #1 audio extracting
    got all the way to
    choosing my video source ie snow dogs from morpheus its an avi. and it was part 1of 2
    this is where i get an erro meassage not compatible or something
    im doing avi2vcd now it works because i cjheck on it and it is a mpeg of what is completed of the encoding but it is very slow seems its going at about 2 frames a second hmmm 13 hours to do 82782 frames.
    There must be something easier,
    If we were to purchase one of the encoder such as the Pioneer one i think at $79.00 would it go smoothly other than doing the audio with the audio decompressor we got with avi2vcd program
    i appreciate your help you can email me if youd like JOYOFWINDOWS@AOL>COM
  8. i think i got it using TMPGEnc and the nimo codec pac, thankyou
