I'm making a series of clips ripped from Youtube and converted to .avi using Tubehunter, which converts the audio to MP3 at VBR, which of course creates problems with VirtualDub. I put clips together using Append clip and the first 4 clips didn't involve an audio stream but the 5th one did even though the rest were ripped the same way. VDub won't append the clip with a different audio stream. I suppose I could just copy the audio stream but I plan to use 10-15 more clips and I don't want to do that every time. How do I fix this?
	Open the file in VD, then under 'Audio', select 'No audio'. Save out the video and audio with 'Direct stream copy'.
 If you want to fix the VBR instead, save it out as a WAV with full processing, then add it back in and using the Lame MP3 ACM codec, and convert it to MP3 CBR audio with full processing. I find VD Mod a little simpler for this.
  Best way to remove subtitle stream?By rmdeboer82 in forum DVD RippingReplies: 1Last Post: 7th Jul 2010, 06:15
  How to add and remove audio stream?By albo23 in forum EditingReplies: 3Last Post: 1st Jan 2009, 10:54
  Remove subtitle stream from MP4By Digiface in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 10:41
  Remove subtitle stream from MKVBy NinjaPanda500 in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 15:59
  How to remove DTS stream for .TS file?By vertical in forum Newbie / General discussionsReplies: 15Last Post: 23rd Oct 2007, 20:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
