Results 1 to 15 of 15
    Mar 2007
    Is there a freeware to copy from an Audio CD to some form of digital (WAV ?), so it can then be turned into MP3 ?
  2. Member olyteddy's Avatar
    Dec 2005
    CDEx or EAC, both of which can output MP3 or WAV.
    Mar 2007
    None of them detects an Audio CD in the drive. I am using Windows XP.
  4. Banned
    Aug 2002
    beautiful
    then navigate to the drive with CD in it or select it :O
    Mar 2007
    Menu options with "Extract CD track" are all greyed out in CDex. I already installed ASPI, but it did not help (and I am still seeing message "Native SCSI Library is not supported... You have to install ASPI ..." when CDex is coming up). I have a CD/DVD reader.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Can you play the CD with WMP ?
    Read my blog here.
  7. Banned
    Jun 2007
    UNREACHABLE
    Newbie way: Winamp
    Nerd way: cdrtools
    Mar 2007
    I downloaded Winamp, it can play the Audio CD (just like WMP did it before), but there is no option to convert it to a file, neither WAV nor MP3.
    Jan 2007
    NJ, United States
    I use AudioGrabber v1.83
    http://www.audiograbber.com-us.net/download.html
    Click on the MP3 icon and adjust the settings to your liking.
    Mar 2007
    AudioGrabber lets me record to a WAV or MP3, file but when either of them played back, they produce only a weird wistle, and then - silence for the rest of the recording.
    Gosh, why is it THAT difficult to get a file from an AudioCD ?
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It's not a copy protected CD is it ?
    Read my blog here.
    Mar 2007
    I don't think so, it is very old, but how I would know for sure ?
  13. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    They have a warning on the case.
    Read my blog here.
  14. Banned
    Jun 2007
    UNREACHABLE
    { Winamp 5.34 }
    Right-click the selected track, choose "Send to",
    choose "Format converter".
    Mar 2007
    Thanks, Midzuki's advice for Winamp worked fine. The only problem - it writes down only the first track, and stops. Is there any way to move to the next one ?
