Hi,
I am trying to convert from VOB to DV for a project a work and when I try to encode I get thi smessage "bin/sh line1: date: command not found" and have no idea what this means. The file is not converted to DV and I am starting to tear my hair out as I need to get this done quickly. Can anyone help with this message and how to fix it?
Many thanks,
Mike
Never seen that error before. It looks like sh (the shell program that processes command line instructions) doesn't understand the command date. Which makes no sense to me, as every Mac should be able to do that, AFAIK. And every conversion with ffmpegX includes a time stamp.Originally Posted by mikehr
Try this: Open /Applications/Utilities/Terminal.app, then type date. It should return the current date and time. Basically the same thing, but then manually.
If your system and disk are okay, and you're running ffmpegX from the Applications folder on your startup disk, then I wouldn't know how to fix this.
Alternatively, you could convert VOB to DV with MPEG Streamclip (free) and the QuickTime MPEG-2 Playback Component ($20).
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 12:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16 -
Error Message
By Kallid in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Jun 2007, 20:13
