  1. Member kippard's Avatar
    Dec 2005
    Image > Pixel Aspect Ratio allows me to set the correct PAR to my DV Widescreen exported still in Photoshop, but when I save a JPG copy it reverts to 4:3. How do I fix the PAR permanently for export/copy (apparently Image > Pixel Aspect Ratio is just a preview)? Thank you!
    Apr 2004
    Miskatonic U
    What this should produce is a 720 x 480 file that will look correct when authored. If you want to preserve the widescreen image then you have to resize to 854 x 480 with a 1:1 PAR and save. (Assuming NTSC, of course)
    Read my blog here.
  3. Member kippard's Avatar
    Dec 2005
    Bless you.
