    May 2007
    Does anyone know what it is or how to download it? thanks!
    Apr 2004
    Miskatonic U
    The only thing that seems to make sense is Quick Slide Show, in which case it is a project file and you would need the program to open it. You can find it here : http://www.narand.com/en/qss/details
    Nothing else seems to really show up as a file type.
    Read my blog here.
    Aug 2006
    @snafubaby,
    I think you're probably referring to quantum streaming segments:
    http://forum.doom9.org/showthread.php?t=124911
    http://www.simutah.org/documents/Dec805luncheon/White%20paper%20v2.0%20rab.doc
    http://www.webservertalk.com/archive374-2006-10-1624062.html
    I ran into them about 5 months ago as described in this post:
    https://forum.videohelp.com/topic329156.html#1701733
    After playing the video, the qss files were cached in a subfolder of the player that you had to install in order to watch the stream. As far as I know, no one has yet re-assembled them into a playable video, but I could easily be wrong about this.
    May 2007
    Originally Posted by Squash
    @snafubaby,
    Exactly!! I am also attempting to download from abc.com, the new show "Pushing Daisies', but it's not working with orbit or any other software i've used. i read the article you posted with great interest, that in firefox, it will cache the files, but am not sure if that was the old software abc is using, or the new stuff. i tried using firefox, but got errors even trying to play PD, saying that the ad data is invalid, whatever that means.
    Aug 2006
    At the time, ABC allowed you to use either the old flash player method or else you could download the new player and use that. I was only able to get the files from the FF cache when I used the old Flash method. I then installed ABC's new video player to try out the new method, and when I played the video with it nothing was appearing in the FF cache, so I went looking in the new player's folder, and sure enough, I could see the qss files popping up in a subfolder as the video played, hundreds of them.
    I haven't been back to ABC since, so I don't know if they still give the option to use Flash. If not, your best legal bet would probably be to try to get the new player running, then use snagit or somesuch, as Baldrick suggested in the other thread.
    The first episode of "Pushing Daisies" was surprisingly good. Hope you get to see it. I read somewhere that the ratings were the highest of any scripted debut on any network since "Lost" premiered back in '04, so they'll probably replay it soon, if the second episode doesn't drop off too much.
    Wish I could be of more help. Hopefully somebody here knows what to do with qss files. Good luck with it.
  6. Yahoo! Search
    Help - Help for Webmasters
    « back to results for "how to play .qmx"
    Below is a cache of http://www.movenetworks.com/wp-content/uploads/movemediaplayersdk_20071214_01.pdf. It's a snapshot of the page taken as our search engine crawled the Web. We've highlighted the words: play playing qmx
    The web site itself may have changed. You can check the current page (without highlighting) or check for previous versions at the Internet Archive.
    Yahoo! is not affiliated with the authors of this page or responsible for its content.
    Move Media Player
    SDK Documentation
    December 14, 2007
    Confidential
    Page
    2
    Address
    796 East Utah Valley Drive
    American Fork, UT 84003
    General Information
    Phone: 801.216.8861
    Fax: 801.756.5806
    info@movenetworks.com
    Sales Information
    Phone: 801.216.8828
    Fax: 801.756.5806
    salesoffice@movenetworks.com
    Table of Contents
    Table of Contents .................................................. .................................................. ................................................ 2
    1 Overview .................................................. .................................................. .................................................. ......... 4
    2 Player Object Creation and Exposure.......................................... .................................................. ................ 4
    2.1 Code to Create Player............................................ .................................................. ...............4
    2.2 Code to Play a QVT or QMX............................................... .................................................5
    3 Player Installation and Version Upgrade .................................................. .................................................. . 6
    3.1 QMP Install Library........................................... .................................................. ..................6
    3.2 Supported Platforms .................................................. .................................................. ...........7
    3.3 QMP Install APIs .................................................. .................................................. ............ 10
    4 Player Communication, Manipulation, and Control .................................................. ..............................10
    4.1 Player APIs .................................................. .................................................. ....................... 10
    4.2 Player Events .................................................. .................................................. .................... 13
    4.3 Play States .................................................. .................................................. ......................... 16
    4.4 Player Settings.......................................... .................................................. .......................... 17
    5 Player Related Web Page Enrichment .................................................. .................................................. .....18
    5.1 My First Player Page Tutorial.......................................... ................................................. 18
    6 Quantum Virtual Timelines (QVT)............................................. .................................................. .................21
    6.1 Introduction to QVT............................................... .................................................. ........... 21
    6.2 Shows versus Clips versus Gap Clips .................................................. .......................... 22
    6.3 QVT Objects........................................... .................................................. ............................. 22
    6.4 Open-ended Timelines .................................................. .................................................. .... 25
    6.5 QVT JSON File Format............................................ .................................................. .......... 25
    6.6 Timestamps and Anchors........................................... .................................................. ....... 28
    6.7 External Metadata.......................................... .................................................. ..................... 30
    December 14, 2007
    Confidential
    Page
    3
    6.8 Miscellaneous .................................................. .................................................. ................... 32
    7 Helper Objects, Methods and Functions, and Debugging......................................... ............................32
    7.1 Importing/Loading Libraries .................................................. .......................................... 32
    7.2 String Functions......................................... .................................................. ........................ 33
    7.3 Utility Functions .................................................. .................................................. ............. 33
    7.4 URL Functions......................................... .................................................. .......................... 35
    7.5 Logging Functionality .................................................. .................................................. ... 36
    December 14, 2007
    Confidential
    Page
    4
    1 Overview
    The Move Networks Video Player SDK is a Javascript-based library containing several
    different types of functionality, all accessible remotely from a Web server via a Web page.
    HTML pages exposing the Move Networks Media Player (QMP) use QVT and related services
    to access and manage the player, hiding complexity and increasing the cross platform
    compatibility of the page.
    In order to a get a player, the page must load the QVT library (
    qvt.js
    ) with the help of the
    Move Networks library (
    movenetworks.js
    Include the QVT library by way of
    movenetworks.js
    with an import of
    qvt
    <script type="text/javascript" charset="utf-8" src="
    http://mvnet.xlontech.net/qm/move/stable/movenetworks.js
    " import="qvt"></script>
    Once loaded, your Web page will have access to the
    MN.QVT
    and
    MN.QVT.QVT
    objects, and
    thus the player object. Use one of the following APIs to create and expose the player.
    Two API options exist for creating a player:
    CreatePlayer()
    and
    EmitObj()
    . The only
    difference between the two is that
    CreatePlayer()
    is essentially a wrapper around
    EmitObj()
    that also attempts to install or upgrade a player prior to calling
    EmitObj()
    . It is
    recommended that
    CreatePlayer()
    be used in “production” player Web pages, since
    CreatePlayer()
    attempts to ensure that the player software is available before calling
    EmitObj()
    MN.QVT.CreatePlayer(parentID, callbackFunction, width, height)
    This API first attempts to install or upgrade a player. When the installation or upgrade is
    complete,
    EmitObj()
    is called. For example:
    <div id="playerParent">The player will go here</div>
    qmp = MN.QVT.CreatePlayer("playerParent", CallMeBack, 480,
    360);
    // now use qmp to control the player
    qmp.Play("http://www.foo.com/biff/baz.qvt");
    MN.Event.Observe( qmp, "PlayStateChanged",
    MyPlayStateChangedFunc );
    parentID
    : Can be either the parent ID or the parent object.
    December 14, 2007
    Confidential
    Page
    5
    callbackFunction
    : Function to be called after the player has been created. The
    parameter that will be passed to the
    callbackFunction
    depends on whether the
    player was successfully created or not. If successful, the player object will be passed.
    If not successful, a value of
    False
    will be passed.
    width
    : (optional) Width of the player in pixels. Defaults to 480.
    height
    : (optional) Height of the player in pixels. Defaults to 360.
    MN.QVT.EmitObj(parentID, width, height)
    The
    EmitObj()
    API is used to create a player instance in the
    parentID
    element without
    checking to see if the player software has been installed. This newly-created player object is
    then returned to the code. Caution should be taken when using the
    EmitObj()
    API because
    errors will occur if the player software has not been installed for use with the user’s browser.
    For example:
    qmp = MN.QVT.EmitObj("playerParent", 480, 360);
    qmp.Play("http://www.foo.com/biff/baz.qmx");
    Note: In the two examples above, either a normal QVT or a QMX URL can be used in the call
    to
    Play
    ; internally, the player converts QMX URLs to a virtual timeline with just a single
    piece of content. See the “QVT Objects” section below for more information.
    parentID
    width
    height
    Play(URL, start=-1, stop=0)
    Once a player object is available, you can play content using the
    Play()
    API.
    Play
    can be
    told to play a .qmx URL, a .qvt URL, a QVT object instance, or a QVT instance as a string. If
    null is passed in instead of a URL, the player’s current QVT object is used rather than loading
    a new one.
    Play()
    can also take an optional start and stop position. If -1 is passed as the starting
    position, an attempt is made to begin play at the most appropriate location. Omitting the stop
    position in a call to
    Play
    results in playing to the end.
    360);
    qmp.Play("http://www.foo.com/biff/baz.qvt", -1);
    December 14, 2007
    Confidential
    Page
    6
    URL
    : Can be a .qmx URL, a .qvt URL, a QVT object instance, or a QVT instance as a
    string. If null is passed instead of a URL, the player’s current QVT object is used.
    Start
    : (optional) Position within the QVT where play should begin. If -1 is
    passed, an attempt is made to begin play at the most appropriate location. Defaults to
    -1.
    Stop
    : (optional) Position within the QVT where play should end. Defaults to the
    end of the QVT.
    Also see the “Creating a Page” tutorial for additional code examples.
    Player installation and upgrade is handled automatically when the
    CreatePlayer()
    API is
    used to instantiate a player. This API uses the QMPInstall library
    qmpinstall.js
    to
    attempt to install or upgrade the player software from across the Internet. Other methods of
    installing or upgrading a player are not available at this time.
    The QMPInstall library (
    qmpinstall.js
    ) handles all the work around installing and
    upgrading the media player in a user’s browser. This includes the initial installation,
    subsequent upgrades, and ongoing status notifications, such as alerting the user of errors
    during the installation.
    Once a call to create a player has been made using the
    CreatePlayer()
    API, the page will
    go through the four steps listed below.
    1.
    A platform check will occur, and the user will be informed if the operating system or
    browser is not supported.
    2.
    If the platform is supported but the user has not installed the player, the user will be
    guided through the installation process.
    3.
    If the platform is supported and the player is installed but out of date, the user will be
    guided through an upgrade process. If, after the upgrade, a restart of the browser is
    needed to load the new player object, the user will be notified.
    4.
    After initialization, the optional player-loaded
    callbackFunction
    (see
    MN.QVT.CreatePlayer()
    above) will be called.
    Note: Customization of these steps is not currently supported. For example, the ability to skip
    step #3 is not allowed.
    The
    callbackFunction
    must expect a single parameter. That parameter will be set to either
    the player object or to a false value. If the callback function is passed a false value, this means
    December 14, 2007
    Confidential
    Page
    7
    that the player was not created successfully. If a non-false value is passed to the callback
    function, the player was created successfully and is ready to play content.
    In the
    callbackFunction
    , you might do a check at the beginning of the function like this:
    function OnPlayerLoaded(player)
    if(!player)
    // There was a problem creating the player object
    return;
    // You could put other code here as well
    // Otherwise you are good to go
    player.Play(someURL);
    Currently, Move Networks Media Player supports the following platforms and browsers:
    Platforms
    Microsoft Windows 2000/XP/Vista
    Apple Macintosh OS X or later (both PPC and Intel)
    Browsers
    Microsoft Internet Explorer 5.5 or later
    Mozilla Firefox 1.5 or later (Windows and Mac)
    Safari 1.3.2 (build 321.5) or later
    The following settings allow the player to determine which platforms and browsers are
    allowed to access any media player experience. Simply set each variable to true or false before
    the call to create the player.
    MN.QMPInstall.allowMozilla
    MN.QMPInstall.allowMacPPC
    MN.QMPInstall.allowMacIntel
    MN.QMPInstall.allowMacSafari
    For Example,
    MN.QMPInstall.allowMacPPC = false;
    would not allow users with a
    PowerPC Macintosh to install the player.
    Install Messages
    The QMPInstall library has a number of messages that it uses during the installation process
    to notify the user of the current status of the installation. These messages are displayed in the
    container which was passed into the
    CreatePlayer()
    function. General styling of these
    messages can be achieved by styling via CSS. The SDK comes with a default set of styles in
    qmpinstall.css
    that pages can include if needed.
    The installation messages have default values but can be customized to fit a page’s need.
    (Please see below for a list of install messages.) To overwrite the values of these messages, set
    MN.QMPInstall.MSG_*
    . The message values should be overwritten after the page has
    December 14, 2007
    Confidential
    Page
    8
    loaded but before the call to create a player. These values can be set to HTML as well as
    JavaScript strings. For example:
    <body>
    <!—Style the messages that appear during the install
    process -->
    <div id=”playerContainer” style=”font:bold 12px Tahoma;
    color:#4D7CB2;”></div>
    </body>
    function OnPageLoaded()
    MN.QMPInstall.MSG_CANINSTALL = ‘
    You do not have the free
    player. Click the download button to install it!.</p> \
    <a href=”#~” onclick=”MN.QMPInstall.StartInstall();”>
    <img src=”install_button.jpg” border=”0”> </a></p>’
    // Call to create player
    This code would display the following if the
    QMPInstall
    library detected that the user
    needed to install the player:
    The following table includes the installation messages and when they will appear to the user:
    Message
    Meaning / When Presented
    MSG_BADOS
    The user is running an unsupported operating system. If
    the string
    %s
    is present in the message, it is replaced with
    a list of supported operating systems.
    MSG_BADBROWSER
    The operating system is supported but the current
    browser is not. If the string
    %s
    it is replaced with a list of supported browsers for the
    operating system.
    MSG_NEEDREINSTALL
    Used when it is necessary to force the end user to start all
    over with the installation process. This will happen
    when the client already on the machine doesn't support
    the kind of upgrade needed, or the attempted upgrade
    didn't work for some reason. This is commonly known as
    the "forced upgrade."
    December 14, 2007
    Confidential
    Page
    9
    MSG_NEEDUPGRADE
    The user has an old version of the player that must be
    upgraded, and the upgrade will be performed
    automatically. The message should include an HTML
    span with the ID
    _qmpUpgradeProgress
    to hold the
    progress messages. This is used when a new client is
    needed before playback can occur. This is commonly
    known as the "foreground upgrade."
    Note: There is also a “background upgrade” which has
    no message associated with it by nature of not bothering
    the end user.
    MSG_UPGRADING
    Displayed repeatedly throughout the upgrade progress.
    If the string
    %s
    is present in the message it is replaced
    with the current progress.
    MSG_UPGRADEFAILED
    An automatic upgrade could not be completed. If the
    string
    %s
    is present in the message, it is replaced with a
    reason for the failure if known.
    MSG_CANINSTALL
    The user does not have the player at all and must install
    it. To initiate the installation, the message should
    include a link that calls
    MSG_INSTALLING
    Displayed once
    StartInstall
    has been called. If the
    string
    %s
    is present in the message it is replaced with
    one of the installation messages below to provide
    additional platform-specific instructions.
    MSG_INSTALL_java
    A Java-based installation is being used; user should be
    instructed to trust or allow the Java applet.
    MSG_INSTALL_win_ie
    The user is on Windows running Internet Explorer and
    will be prompted to download and run an executable file
    MSG_INSTALL_win_mozilla
    The user is on Windows running Firefox and will be
    instructed to download and run an executable file to
    install the player.
    MSG_NEEDRESTART
    An upgrade completed, but the new version could not be
    loaded. The user needs to restart the browser in order to
    complete the upgrade.
    December 14, 2007
    Confidential
    Page
    10
    CanPlay()
    Returns true if the player is installed and up to date. Use this to determine if the user is able to
    view content.
    InstallRequired()
    Returns true if an installation of the player is needed to play content.
    UpgradeRequired()
    Returns true if an old version of the player is installed but requires an upgrade.
    4.1 Player APIs
    CurrentBitRate()
    Returns the bit rate of the most recently played streamlets, in Kbps.
    CurrentClip()
    Returns the index in the timeline of the currently playing clip.
    CurrentPlayState()
    Returns the current state of playback as an integer. Please refer to the “PlayState” section for
    more information.
    CurrentPosition(position)
    Sets the current position in playback. The position can be given in either seconds or a
    timestamp string. If called with no arguments, the current position in playback is returned. A
    start value of -1 instructs the player to determine where playback should begin. If position
    exceeds the duration, playback starts at or near the current end of the timeline. If the position is
    less than 0 and not -1, playback starts at the beginning of the timeline.
    CurrentQVT()
    Returns the current QVT object being played. Call this when the QVT object is needed
    temporarily; do not save a reference to the returned object. See section 6.3 for more
    information.
    Duration()
    Returns the duration of the timeline in seconds.
    Encrypted()
    Returns
    true
    if any of the content’s sub-streams are encrypted and require a key for playback.
    FillColor(color)
    Sets the background fill color of the player. Use HTML color strings (for example, #FFFFFF).
    GetCurrentURL()
    Returns the URL currently being played. If nothing is playing, an empty string is returned.
    December 14, 2007
    Confidential
    Page
    11
    GetSetting(name)
    Retrieves a player setting from the operating system’s registry. Returns an empty string if no
    value has been set with given name.
    HasAudio()
    Returns
    true
    if the content currently playing has an audio stream.
    HasVideo()
    Returns
    true
    if the content currently playing has a video stream.
    Height(height)
    Sets the player’s height. If called with no arguments, the current height of the player is
    returned.
    InGap()
    Returns
    true
    if the current position is inside a gap. See section 6.2 about gap clips.
    Live()
    Returns
    true
    if the current stream is live. A live stream is an open-ended timeline.
    Load(URL)
    Like
    Play
    , this method loads the given URL and causes a
    TimelineLoaded
    event to fire
    when loaded. Unlike
    Play
    , however, playback does not start automatically.
    MetadataByIndex(index)
    Retrieves the value of the metadata at the given index. Use
    MetadataCount
    to find the
    number of pieces of metadata attached to the current content.
    MetadataByName(name)
    Retrieves the metadata value associated with the given name. Returns an empty string if there
    are no metadata by that name.
    MetadataCount()
    Returns the number of pieces of public metadata attached to the current content.
    MetadataName(index)
    Retrieves the name of the metadata at the given index point. Use
    MetadataCount
    to find the
    Muted(true or false)
    When value is set to
    true
    , sound is muted during playback. If called with no arguments, the
    player’s current muted state is returned.
    Paused(true or false)
    true
    , playback is paused. If called with no arguments, the player’s
    current paused state is returned.
    Start playback of the given URL. URLs should end in a .
    qvt
    or .
    qmx
    extension. The start and
    stop parameters can be given in either seconds or a timestamp string (for example,
    December 14, 2007
    Confidential
    Page
    12
    05:12:25.123
    ). The start parameter is optional and defaults to
    -1
    . A start value of
    -1
    instructs the player to determine where playback should begin. For live content this is as
    close to “live” as possible. For non-live content, this is at the beginning of the content. Any
    non-zero start value seeks to that position before playback starts. If a stop value is given,
    playback stops at that point.
    Note: This method for setting the start time (URL with included start value) is more efficient
    than calling
    Play
    and then setting the
    CurrentPosition
    PlayClip(qmxURL, title=””, start=-1, stop=-1, playStartPos=-1)
    Plays a portion of a clip, restricting playback to the specified range. The
    title
    start
    stop
    and
    playStartPos
    parameters are optional. The
    start
    and
    stop
    parameters can be
    given in either seconds or a timestamp string.
    PutSetting(name, value)
    Saves a player setting to the operating system’s registry. Unknown settings are ignored.
    Please refer to the
    PlayerSettings
    section for more information on valid settings.
    RealAspectRatio()
    Returns the actual video windows aspect ratio of the current content as a number (width
    divided by height).
    RegistryVersion()
    Returns the version of the player currently installed, according to the registry.
    Set(variable, value)
    Assigns the given value to the given variable. For example:
    var myfunc = "qmp.Set('SelectStreams', '0, -1, -1, -1, -1,
    -1,-1,-1,-1,-1,-1,-1');";
    // assure that the amount of flags is equivalent to the
    // profile set in use
    myfunc += "qmp.Set('Commit', '1');";
    flash.external.ExternalInterface.call("eval", myfunc);
    SetAutoPlayNext(value)
    When set to true, playback will advance to the next QVT when the current timeline is finished
    playing. If not set to false, will default to true and playback of the next QVT will occur
    automatically unless a playback stop position was given.
    SingleStep()
    When video playback is paused, calling this function will advance playback by one video
    frame, if possible.
    StartTimestamp()
    Returns the starting time of the current content in seconds since the epoch (January 1, 1970
    GMT). Use this to map content time to actual time. This function can be especially useful for
    getting the actual time for live content.
    Note: In JavaScript the
    Date
    object is in milliseconds.
    December 14, 2007
    Confidential
    Page
    13
    Stop()
    Stops playback. If nothing is playing, calling this has no effect.
    StopScrubbing()
    Stops scrubbing.
    UserAspectRatio(ratio)
    Sets the user-specified aspect ratio. This function is used to force the display to use a different
    aspect ratio. Calling with a ratio of 0 tells the player to use the real aspect ratio. If called with
    no arguments, the current user-specified aspect ratio is returned.
    Version()
    Returns the version of the player currently loaded in the browser.
    Note: The version and registry version values can be different.
    VideoHeight()
    Returns the video window height, in pixels, of the content currently playing. Returns zero if
    nothing is playing.
    VideoWidth()
    Returns the video window width, in pixels, of the content currently playing. Returns zero if
    nothing is playing.
    Volume(level)
    Sets the current volume level of the player, from 0 to 100 inclusive. If called with no
    arguments, the player’s current volume level is returned.
    Width(width)
    Sets the player’s width. If called with no arguments, the current width of the player is
    returned.
    4.2 Player Events
    AudioControl(muted, volume)
    Fired when the UI needs to be updated to reflect a change in the state of the audio controls. For
    example, after setting the Muted or Volume properties, this event will fire with the new values.
    The reason this is handled separately is that changes to the audio controls' state may occur
    outside the scope of the application (for example, the user clicks the Mute checkbox in the
    Wave column of the Windows Volume Control applet).
    BitmapReady(status, url)
    Fired when
    SendBitmapAsync
    or
    SendBitmap
    completes. The resulting status value is 0
    on failure and 1 on success with the URL parameter containing the URL of the uploaded file.
    BitRateChanged(newRate)
    Fired when the playback bit rate changes. The
    newRate
    parameter is the number of Kbps.
    Error(msg)
    Fired to pass an error message to the Web page (for example, a bad URL). The parameter is a
    human-readable string.
    December 14, 2007
    Confidential
    Page
    14
    MutedChanged(newMuted)
    Fired when the player’s muted state changes. The
    newMuted
    parameter is
    true
    if the player is
    muted.
    NextClip(clipNumber)
    Fired when the player transitions from one clip to the next in the timeline.
    NextTimeline(url)
    Fired when the player has finished playing the current timeline and is automatically moving to
    the next linked timeline.
    NotSustainable(reason)
    Fired for the lowest priority stream when any playing stream encounters too many frame drops.
    The player cancels the most recent not sustainable event when all streams go a period without
    a further frame drop. A reason code is returned.
    PausedChanged(newPaused)
    Fired when the player’s paused state changes. The
    newPaused
    parameter is
    true
    if playback
    is paused.
    PlayStateChanged(oldPlayState, newPlayState)
    Fired when the player transitions to a new play state. Please refer to the “P lay State Values”
    section for more information.
    Script(key, value)
    Fired when the player encounters an embedded script event. The key and value data are
    publisher-defined strings.
    ScrubBumper(atStart)
    Fired when a scrubbing operation has reached the beginning or end of the scrub range. Since
    scrubbing is currently only supported within the clip, and not across clips, the scrub range is
    the play range of the clip the user was in when they chose to begin scrubbing.
    ShowChanged(showNumber, showTitle)
    Fired when playback has moved to another item in the playlist.
    TimelineLoaded(qvt)
    Fired when the playlist for a timeline has finished loading.
    VolumeChanged(newVolume)
    Fired when the player’s volume has changed. The
    newVol
    parameter is the current value of the
    player’s volume from 0 to 100 inclusive.
    Event Handling
    The Move Networks SDK includes an event handling library. The event library extends the
    browser’s
    Event
    object to include functions for cross-browser event handling and player
    event handling.
    To add an event handler to an object, use the following:
    December 14, 2007
    Confidential
    Page
    15
    MN.Event.Observe(object, eventName, listenerFunction)
    For example, the following would set up a function to be called every time the player’s bit rate
    changed:
    function OnBitRateChanged(newRate)
    { // Function names can be anything of course
    log(‘The bit rate changed to ‘ + newRate + ‘ Kbps);
    MN.Event.Observe(playerObject or ID, ‘BitRateChanged’,
    OnBitRateChanged);
    Note: When using the event library, event names should not include the
    On
    prefix. (for
    example,
    onclick
    would be passed in as
    click
    To remove an event handler, use
    MN.Event.StopObserving(object, eventName,
    listenerFunction)
    For example, the following would stop observing the event that we started observing in the
    above example:
    MN.Event.StopObserving(playerObject, ‘BitRateChanged’,
    OnBitRateChanged)
    Note: In order to stop observing an event correctly, the exact same values must be passed into
    the
    StopObserving
    function that were passed into the
    Observe
    function. If the arguments
    don’t match, the event will continue to be observed, and observation of a different event may
    be stopped by accident.
    In addition to hiding browser-specific details, these event functions also make it possible to
    “ stack” multiple listeners for a single event. Stacking allows multiple functions to listen for
    the same event being fired by an object. When the object fires the event, all the functions
    listening for that object’s event are called.
    For example, the following would allow you to have two functions listening for the player’s
    PlayStateChanged
    event:
    MN.Event.Observe(playerObject,‘PlayStateChanged’, UpdateUI)
    OnPlayStateChanged)
    When the player fires the
    PlayStateChanged
    event, both the
    UpdateUI
    and
    OnPlayStateChanged
    functions are called.
    Note: When stacking event handlers, there is no guarantee as to which order the listening
    To ensure that event handlers aren’t accidentally overwritten, it’s generally preferable to use
    the above functions for any event handling where multiple handlers might be used. For
    December 14, 2007
    Confidential
    Page
    16
    example, instead of specifying the page load/unload event handlers in the BODY HTML tag
    (for example,
    <body onload=”…”
    ), they can be handled by observing the
    load
    event on the
    window object:
    MN.Event.Observe(window, “load”, MyLoadFunc)
    Please refer to the “Creating My First Page” tutorial to learn more.
    Add an event handler to the given object. The object parameter may either be the object or the
    object’s ID. The
    listenerFunction
    is called when the object fires the event.
    MN.Event.StopObserving(object, eventName, listenerFunction)
    Remove an event handler for the given object. The object parameter may either be the object or
    the object’s ID. If no match for the event handler is found for the given object, the call is
    ignored.
    MN.Event.RemoveAllObservers()
    Removes all event handlers registered through
    MN.Event.Observe
    4.3 Play States
    The current state of playback can be retrieved by calling the player’s
    CurrentPlayState
    function. The player’s
    PlayStateChanged
    event is fired whenever this state changes.
    Functions listening for this event will be passed both the old and new play states. The SDK
    library provides a play state helper to display the play state as a text string rather than as a
    numerical value. This object is referenced using
    MN.QMP.PS
    . For example:
    var state = player.CurrentPlayState();
    if (state = = MN.QMP.PS.ERROR)
    // do something with the error
    $(“playState”).innerHTML = “Current PlayState is “ +
    MN.QMP.PS[state];
    The strings returned by the play state helper are the names of the states (see table below). It is
    important to note that the play states returned by the player and SDK libraries are numbers
    and not text strings. The play state helper converts these values into descriptive text strings
    that can be displayed to the end user.
    When the player is first created, its state is
    Init (0)
    . Once the player receives the command
    to play content, the state switches to
    Opening (1).
    The progression of the play states
    during playback is usually something like:
    Opening > Authorizing > Loading > Playing > Media Ended.
    The
    Waiting
    state (255) does not normally need to be handled. If the player is in this state, it
    usually means that the publisher is not keeping up with the pace of playback. This happens
    when the publisher is late publishing additional content to an open-ended timeline.
    Play State
    Number
    Name
    Description
    December 14, 2007
    Confidential
    Page
    17
    0
    Init
    Initializing and creating player interface
    1
    Opening
    Opening video content
    2
    Loading
    Loading the first streamlets of the content
    3 Playing
    Playing
    content
    4
    Stopped
    Playback of content has stopped as a result of calling
    the player Stop function
    5
    MediaEnded
    The end of the current content has been reached
    6
    Error
    An error has occurred with the player
    7
    Stalled
    Playback of content has stalled
    8
    Authorizing
    The player is requesting the server for authorization to
    play content
    255 Waiting
    Content is late being published for open-ended
    timelines
    4.4 Player Settings
    Note: These settings work in the majority of cases. They are present primarily for
    testing purposes and should not be changed without prior consultation.
    The player has a few user-selectable settings that modify its behavior. See the “P layer APIs”
    section for more information on retrieving and modifying setting values.
    To change a setting simply call
    player.PutSetting(name, value)
    . For example:
    Player.PutSetting(“Renderer”, “dx”).
    To retrieve a setting call
    player.GetSetting(name)
    To change the setting to its default call
    PutSetting
    with an empty string value, for example
    PutSetting(“Renderer”, “”).
    Calling
    GetSetting()
    or any setting other than
    RendererDesc
    returns that value last
    requested, not the one in use. Use the value of
    RendererDesc
    for information about the
    renderer currently in use.
    Name
    Value
    Comments
    December 14, 2007
    Confidential
    Page
    18
    RendererUseOverlays
    yes,no
    This tells the renderer whether or not to attempt
    to use video overlays, if available. This setting is
    used only by DirectX renderer.
    RendererDesc
    (read-only)
    Retrieves a text description of the renderer in use.
    Renderer
    vfw dx
    Selects which renderer to attempt to use for
    video: dx (DirectX, the default), vfw selects the
    older Video For Windows renderer.
    AudioRenderer ds
    waveout
    Selects which audio renderer to attempt to use
    for audio:
    ds
    (DirectSound),
    waveout
    selects
    the WaveOut audio renderer.
    The Move Networks Video Player SDK supports the development of feature-rich player Web
    pages. The Web page enrichment features are found in the following files:
    autoplayer.js
    minimal.js
    playerui.js
    shinyred.js
    validate.js
    widget.js
    In order to have enriched pages, one must first have a basic page. This tutorial shows how to
    create such a page.
    This tutorial covers the basics of putting the Move Play Client into a Web page. The 40 lines
    of code for this tutorial can be found below, at the end of section 5.1. This tutorial will
    reference that code, giving examples with the corresponding line number(s). If you run into
    any problems, see the “Troubleshooting” section below.
    First you need to include the URL to the
    movenetworks.js
    file and import the
    qvt.js
    library (line 8). This
    <script>
    tag should go into the body of your page.
    <script language=”javascript”
    src=”http://www.foo.com/url/to/movenetworks.js”
    import=”qvt”></script>
    The QVT library aids in embedding the player into your Web page.
    December 14, 2007
    Confidential
    Page
    19
    Next add a script section to the body of your page to put the functionality to create and use the
    player (line 12).
    <script language=”javascript”>
    // Code will go here
    </script>
    Define a function to be called when the window
    load
    event is fired, and include a call to
    show the logging pane and log a message to it (lines 15–18) Then observe the window load
    event passing in this function (line 37).
    MN.Log.ShowPane(500);
    log(‘Page
    loaded’);
    MN.Event.Observe(window, ‘load’, OnPageLoaded);
    Open the page in a browser. If you see the logging page with your log message in it, you have
    successfully loaded the Move Networks Client SDK. Showing the logging pane (line 17) is
    not necessary but is a good idea to always have visible during development of a page.
    When creating a player, two things are needed to pass in to the
    CreatePlayer()
    API:
    1. An HTML container to put the player object in.
    2. A function to be called once the player has been created.
    Create a container to hold the player in the body of the page, and give it an ID (line 10).
    <div id=”myplayer”></div>
    Now define a function to be called once the player has been created (lines 22–35). This
    function should check to make sure the value passed to it is not false. If the value is false, this
    means that there was an error creating the player. You should also add a global variable to
    hold the player object so that it can be referenced when calling other functions (line 13).
    var qmp = null; // will hold the reference to the player
    object
    function OnPlayerLoaded(playerObject)
    if(!playerObject)
    logError(‘Failed to create the player’);
    return;
    else
    // the player was successfully created and you
    are good to go
    December 14, 2007
    Confidential
    Page
    20
    qmp
    playerObject;
    qmp.Play(‘http://qmedia.xlontech.net/100170/streamlets/ \
    themagicofflight_on2/output.qmx’); // Play some content
    You are now ready to create the player. To create the player, call
    MN.QVT.CreatePlayer(playerID, callbackFunction, width, height)
    (line
    19). Place this call in the
    OnPageLoaded
    function that you already set up. The
    MN.QVT.CreatePlayer
    function takes optional width and height parameters to set the
    player’s initial width and height.
    MN.QVT.CreatePlayer(“myplayer”, OnPlayerLoaded, 480, 360);
    That is it! When you open the page in a browser, you should see video playing. If you don ’t
    see video or are having problems, refer to the “Troubleshooting” section below.
    Note: Pages that use the Move Networks Client SDK should typically specify a
    DOCTYPE
    like this (see line 1):
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0
    Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-
    transitional.dtd">
    An example code listing:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html>
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-
    1">
    <title>Creating a player</title>
    </head>
    <body>
    src="http://qmedia.xlontech.net/100348/qm/latest/movenetworks.js"
    <div id="mplayer"></div>
    <script language="javascript">
    var qmp = null;
    log('Page Loaded');
    MN.QVT.CreatePlayer("myplayer", OnPlayerLoaded, 480, 360);
    if(!player)
    logError('Failed to create the player');
    return;
    else
    // You are good to go
    December 14, 2007
    Confidential
    Page
    21
    qmp = player;
    qmp.Play('http://qmedia.xlontech.net/100170/streamlets/themagiccofflight_o
    n2/output.qmx');
    MN.Event.Observe(window, 'load', OnPageLoaded);
    </script>
    </body>
    </html>
    QVT provides services which allow one or more content segments to be sequenced as a single
    virtual content timeline within a single QVT (stored in a file with the extension .
    qvt
    ). Like
    many elements of Web-based software, they are stored on the Web server but consumed by the
    Web client.
    When playing a QVT, the player tries to treat the entire timeline as a single piece of content.
    This means that when one clip in the timeline finishes, playback moves to the next clip in the
    timeline. Only when playback of all clips has finished does the player enter the
    MEDIAENDED
    playstate.
    QVT files are simply text files stored in Javascript Object Notation (JSON) format
    http://www.json.org/
    ), which makes them interoperate with different languages as well as
    XML, but without the downsides of XML (such as bloat and the relative difficulty of reading
    and writing XML).
    A JSON string is white-space agnostic and basically has the form of the following line:
    { property1:value1 ... , propertyN:valueN }
    where property has the form of a double-quoted string and value can be either a double-quoted
    string, a JSON string, or a list of JSON strings enclosed in brackets ( “[ ]”). Only double-
    quoted strings are legal in JSON. See
    http://ww w.json.org/
    for a more formal syntax
    specification.
    QMP now ships with a built-in JSON verifier to ensure that no harmful code is included in the
    QVT. The raw JSON text is evaluated to create a JavaScript object.
    QVT files can have links to next and previous timelines. If a QVT has a next-QVT link, when
    playback of the current timeline ends, the player can automatically move to the next timeline
    (controlled using the
    SetAutoPlayNext(true/false)
    API). When playback moves to
    the new timeline, internally a call to
    Play(newQVT, 0)
    is made. Note that if playback does
    not reach the end of the timeline (because a stop position was requested), then playback will
    not automatically move to the next timeline, regardless of whether or not Set
    AutoPlayNext
    is enabled.
    December 14, 2007
    Confidential
    Page
    22
    A QVT file is made up of a list of URLs that represent the various media clips to play as part of
    the timeline. Each clip, however, may be made up of several shows.
    For example, the clip itself could cover an entire day's worth of TV programming. Even though
    it is a single clip, many shows were played throughout the day, and each show needs its own
    metadata.
    If a clip covers multiple shows, the per-show metadata can be specified using the
    .shows
    property in a QVT file (see “QVT File Format” below for more info). Otherwise, the clip
    metadata will be treated as if it were show metadata and will be accessible accordingly.
    If a clip does not have a URL specified, it is considered a gap or filler space between clips. A
    Web page using QVT could choose to skip the gap or allow it to "play" (the video window is
    not updated while a gap is playing, so a Web page could display an alternate image during
    that time, for example). A gap clip should not have a list of shows, but it can have arbitrary
    metadata.
    Instead of having shows tied to clips, a top-level show list can be given instead. This list has
    the same format as clip-level show lists, but the shows map directly to timeline times
    regardless of where clips begin and end. This can be useful in situations where multiple clips
    correspond to a single show list (for example, if the Atomizer is set to record all day but is
    restarted halfway through).
    If a show list is longer than the timeline at the time the QVT is loaded, it is truncated to make it
    match the actual timeline duration. Shows that begin beyond the end of the timeline are
    ignored, and if a show lasts longer than the timeline it is shortened. If you are using live
    content (such that the timeline continues to grow), simply mark your QVT file as reloadable
    and over time the list of shows that is included will grow automatically.
    6.3 QVT Objects
    QVT Javascript objects are created from the contents of a .
    qvt
    file, a JavaScript string that
    mirrors the contents of a .
    qvt
    file, or from another QVT object. They are separate from player
    objects.
    A QVT object contains all the information about the contents of a timeline. You can create a
    QVT object by either telling the player to play a URL (and then calling
    player.CurrentQVT()
    ) or with
    MN.QVT.AcquireQVT(url or str)
    Because QVT objects may automatically reload themselves, an internal cache of current QVT
    objects is maintained to prevent multiple copies of the same QVT from overrunning the server
    with update requests. If you obtain direct access to a QVT object via
    MN.QVT.AcquireQVT
    you need to call
    MN.QVT.ReleaseQVT(qvt)
    when done with it to ensure the cache stays
    up to date. Failure to do this won't necessarily cause errors, but if a user views many QVT
    objects in a single session, not calling this function could leave a lot of them lying around
    even when you're no longer using them.
    QVT objects have the following APIs:
    ClipToTimeline(clipNum, clipPos)
    December 14, 2007
    Confidential
    Page
    23
    Given a clip number and position, returns an overall timeline time.
    DecRef()
    Decrements the reference count for this object. This should be called once for each call to
    IncRef
    Duration(showNum)
    Returns the duration of the specified show. If
    showNum
    is omitted, returns current duration of
    the entire timeline.
    GetSource()
    Returns the URL (or other input) passed to the object constructor.
    GetTimelineNow()
    For anchored timelines, returns a value in timeline time (in seconds) that corresponds to right
    now. For unanchored timelines, returns 0.
    GetSummary()
    Makes a "snapshot" of the current QVT and returns it; useful for generating a graphical version
    of the timeline for presentation to the user. Returns an object with the following properties:
    .duration
    - the total duration of the timeline
    .live
    - the value of
    qvt.HaveAnyLive()
    .shows
    - an array of show objects. Each show has the following properties:
    .startTime
    - when the show starts, in timeline time
    .stopTime
    - when the show ends, in timeline time
    .duration
    - the duration of this show, in seconds
    .title
    - the title of this show, if any
    .showNum
    - the show number (0-based)
    .isGap
    - true if this show is a gap instead of a clip of content
    HaveAnyLive()
    Returns true if any clips are marked as live.
    IncRef()
    Increments the reference count for this object. Use this when you need to save a reference to a
    QVT object, for example:
    theQVT = qmp.CurrentQVT().IncRef();
    InitialLoadDone()
    Returns true if the first-time load of this QVT has finished.
    IsAnchored()
    Returns true if this timeline is anchored; see the “Timestamps and Anchors” section for more
    info.
    IsGap(showNum)
    Returns true if the given show is a gap.
    December 14, 2007
    Confidential
    Page
    24
    IsLoading()
    Returns true if an asynchronous load or reload of this QVT is underway.
    IsOpenEnded()
    Returns true if this QVT is open-ended; see the “Open-ended Timelines” section below for
    more information.
    IsValid()
    Returns true once the QVT is fully loaded and has valid clips.
    Metadata(name, showNum)
    Returns the metadata for the given name, if any. If
    showNum
    is omitted, returns the metadata
    value for the QVT itself. Both QVT objects and individual shows can have arbitrary metadata.
    NextURL()
    If this QVT has a reference to a "next" timeline, returns its URL. This is used for linking
    timelines together.
    PosToDatetime(pos)
    Returns a datetime object representing the given position in the timeline converted to
    broadcast time. The returned object has the following members: year, month, day, hour, minute,
    second, dow (for “day of week,” Sunday=0). For example, if the timeline starts at Feb 1, 2005 at
    9:00AM PST, then calling
    PosToDatetime(3602
    ) would return an object with members
    giving the time of 10:00:02 on Feb 1, 2005, regardless of the user's local timezone. If the
    timeline does not have a timezone set (for example,
    Timezone()
    returns null), the returned
    time will be in UTC. The month value is 1-based (Jan.=1, Feb.=2, etc.).
    PrevURL()
    If this QVT has a reference to a "previous" timeline, returns its URL.
    PrimaryURL()
    If the QVT object has a
    primaryQVTURL
    member, returns it. If not, returns the QVT URL used
    to create the object. If no URL was used (for example, if a JavaScript object was passed in to
    the constructor), returns a false value. This function exists to aid pages that need a more
    permanent URL when a temporary URL was used to initiate playback (for example, if the
    Atomizer produced a
    today.qvt
    file and the viewer uses the Send to a Friend feature. On the
    next day,
    today.qvt
    would point to the wrong day, so instead the Atomizer would include
    a primary URL, and the Web page would call this API to include the correct URL in the Send
    to a Friend email).
    ShowCount()
    Returns the number of shows in this timeline.
    StartDatetime()
    Returns a datetime object (see
    PosToDatetime
    , below) representing the date and time when
    this timeline starts, in broadcast time. If the timeline does not have a timezone set (for example,
    Timezone()
    returns null), the returned time will be in UTC.
    StartTime(showNum)
    Returns the start time of the specified show (show numbers are 0-based).
    December 14, 2007
    Confidential
    Page
    25
    StartTimestamp()
    Returns the timestamp value for the timeline, if it has one.
    StopTime(showNum)
    Returns the stop time of the specified show.
    TimelineToClip(pos)
    Given a time in the timeline, returns a position object.
    TimelineToShow(pos)
    Given a time in the timeline, returns a show number.
    Timezone()
    Returns the timezone value for this timeline, if one is specified; null otherwise.
    Title(showNum)
    Returns the title of the specified show, if any. If
    showNum
    is omitted, returns the title of the
    entire timeline.
    Note that
    MN.QVT.ReleaseQVT(x)
    and
    x.DecRef()
    are functionally equivalent, but for
    clarity you should use
    ReleaseQVT
    if you obtained the QVT via
    AcquireQVT
    and
    DecRef
    if you obtained it via
    IncRef
    QVT files with a
    .reload
    property are said to be open-ended, which means that the timeline
    is considered to be incomplete and will be edited additionally over time. Open-ended
    timelines allow publishers to modify the future sequence of clips, even if some users are always
    viewing the timeline.
    If you create an open-ended timeline, be sure to remove the
    .reload
    property once the
    timeline is finalized (once you intend to make no further changes) so that the timeline is no
    longer open-ended.
    If a user plays an open-ended timeline and reaches its end before additional clips have been
    added (or before the QVT file is edited to no longer be open-ended), playback will pause at the
    end of the timeline and the player will enter the
    WAITING
    playstate (255). Later, when an
    edited version of the timeline is published, playback will move to the next clip if new clips
    were added. If the timeline was edited to no longer be open-ended, the behavior will be the
    same as if the timeline wasn't open-ended to begin with.
    Note that editing the range of a clip in an open-ended timeline will not have any effect if the
    user is already playing that clip (that is, if a clip has the range 10–20, and you edit the range
    to 10–100 after someone has already started playing that clip, that user will still have
    playback stop at 20, even if the new version of the timeline is loaded before playback of the
    clip ends).
    The raw JSON text is evaluated to create a JavaScript object. QVT objects can have the
    following properties; all of them are optional except for
    .clips
    December 14, 2007
    Confidential
    Page
    26
    .title
    - A title for the entire timeline.
    .prev
    - A QVT URL pertaining to a timeline that precedes the current one sequentially.
    .next
    - A QVT URL pertaining to a timeline that immediately follows this one. If this member
    is present, the player will automatically begin playing the next QVT when it reaches the end of
    the current QVT.
    .reload
    - The number of seconds to wait before automatically reloading the QVT to see if it
    has been updated. Do not specify this parameter unless you actually intend to edit the timeline
    at some point. Because each reload puts additional load on the remote servers, avoid using too
    low an interval except in testing. Typically, you should not use an interval of less than 300 (5
    minutes). When the interval is reached, the QVT is asynchronously reloaded and a
    TimelineLoaded
    event is fired so that the application or Web page can recreate any visual
    representation of the timeline (since new shows may have been added). See also the “Open-
    ended Timelines” section above for more information.
    .metadata
    - A URL to a QVT file containing any metadata for this timeline. See the
    “ External Metadata” section below for more information.
    .timestamp
    - A timestamp value as a string. Typically consists of the type (UTC or day), a
    number representing the UTC time in seconds, or the offset relative to the start of the day.
    Optionally can include anchor and wrap flags. See “Timestamps and Anchors” for more
    information. If this member is not specified, a timestamp will be calculated based on the
    timestamps of the clips.
    .showsTimestamp
    - Like timestamp, except that its time specifies the point in time
    that corresponds to the beginning of the show list. If
    showsTimestamp
    is present, the
    QVT library will perform whatever work is necessary to ensure that the show line properly
    maps to the timeline. See “Timestamps and Anchors” for more information. At this time,
    only UTC timestamps are supported, so a valid use might look like
    showsTimestamp:utc,1144951329
    .timezone
    - The number of hours (as a floating point number) to add to a UTC time to derive
    broadcast time for this timeline. For example, for Mountain Daylight Time a QVT could include
    timezone:-6.0
    . If the timezone is set, then the QVT
    Timezone
    StartDatetime
    , and
    PosToDatetime
    APIs work as expected.
    .shows
    - A list of shows and show metadata (see information on clip-based shows below or
    the section “Shows versus Clips versus Gap Clips” above) for more information. A QVT
    should not have both a top-level show list and clip-level show lists. If both are present,
    however, the top-level list is used.
    .clips
    - An array of sub-objects, with each one corresponding to a media clip to play. Clip
    objects have the following properties:
    .url
    - A valid QMX URL to play. If not specified, this clip is considered a gap clip.
    .range
    (optional) - The portion of the media to play (for example:
    range:10,25
    would play from time index 10 to time index 25, and then the player would move on
    December 14, 2007
    Confidential
    Page
    27
    to the next clip). Partially specified ranges are allowed too (for example, "100," but
    they take longer to load because the QVT library will download and inspect the
    QMX file to discover its duration. Ranges without an end time are not allowed for
    gap clips; a gap clip without an end time is removed from the QVT.
    shows
    (optional) - A list of show metadata objects. Each object should have a
    .start
    property, that tells the start time, in seconds, of the show relative to the
    clip. Other properties can be added as custom metadata, although QVT will use the
    .title
    property if present. Gap clips should not have a show list.
    .timestamp
    - A timestamp value in seconds UTC. Used to explicitly set the
    timestamp value for a clip. If no QVT timestamp is present, or if it does not specify an
    offset value, this clip's timestamp will be used to calculate an overall timestamp. A
    live clip is automatically given a timestamp based on the QMX start timestamp after
    adjusting for the clip's range. If multiple clips have a timestamp specified, the first is
    used. Note that the timestamp value given maps to the start of the selected range.
    Other arbitrary properties are allowed as additional metadata; if a
    .title
    property is present
    it is accessible via the
    QVT.Title(i)
    API.
    Below is a sample QVT file:
    "title":"My first QVT file",
    "clips":
    {"url":"qsp://Cool/Travel/Hawaii/output.qmx",
    "range":"100,300",
    "shows":
    { "title": "Intro" },
    "start":50,
    "title":"History
    and
    Heritage" },
    "start":100,
    "title":"Activities
    and
    Attractions" },
    { "start":180, "title":"Outro" }
    {"range":"0,10", "title":"A ten second gap"},
    {"url":"http://whatever/pepsi/output.qmx",
    "biff":"freep",
    "title":"Thousand Hand Slap", "range":"9,"},
    "url":"qsp://junk/stuff/zackandcody/output.qmx",
    "title":"Ugh"}
    "next":"http://127.0.0.1/qvt/second.qvt",
    "timezone":-7.0,
    "author":"Dave"
    December 14, 2007
    Confidential
    Page
    28
    Note in the above example that both clips and the entire QVT can have arbitrary metadata, and
    that the range on a clip is completely optional. The first clip actually covers multiple distinct
    segments, so it provides
    .shows
    to list per-show metadata. Note that the show times are
    relative to the start of the clip, and that
    .start
    is optional for the first show (actually, even if
    you specify a start value, QVT will always set the first show's start time to 0). Note that in the
    last clip, the end is not specified; QVT will load the QMX file to determine its length, and then
    set the clip end time automatically. In the third clip, no range is specified, so the entire content
    will be played. Between the two clips is a 10-second gap.
    General purpose content management and QVT creation tools will soon be available. Until
    then, it can be helpful to use JavaScript's
    eval
    function to verify that a QVT is syntactically
    correct. For example, if you have the QVT string data in a variable called raw, you can verify
    that the QVT is valid with:
    var obj;
    eval("obj=" + raw);
    alert(obj.clips.length); // and/or inspect the result in
    other ways
    The most common mistake when creating a QVT by hand is using single quotes around keys
    and values. While valid JavaScript, it is not valid JSON—always use double quotes!
    A timeline can have an overall timestamp (reported by
    qvt.StartTimestamp()
    in seconds,
    UTC) that reflects when the timeline started in actual (real-world) time. This timestamp can be
    displayed to the user or used to sync to a non-QVT metadata source if needed, but note that a
    timeline is not required to have a timestamp at all. If a QVT-wide timestamp is specified, it is
    used. Otherwise, each clip is inspected for a timestamp property. The first one found will be
    used as the timestamp, after adjusting for the duration of the previous clips (in other words, if
    the timeline has clips A,B,C, and D, and C has a timestamp, then the timeline timestamp will be
    C.timestamp - (A.duration + B.duration)
    ). Note that live clips are automatically
    given timestamp properties because the QMX always gets loaded.
    Currently, two types of timestamps exist: explicit time-based and day-relative. Time-based
    timestamps are in seconds UTC and specified like
    utc,1137687669
    (meaning Jan 19, 2006
    9:21:09 MST). Day-relative timestamps make the timeline appear to start relative to the start of
    the day in the user's local timezone. Day-relative timestamps can also have an offset value
    telling how many seconds past the start of the day the timeline starts. For example,
    day,3600
    means the timeline should appear to start 3600 seconds after midnight, or 1 AM in the user's
    local time. If an offset is omitted, it is assumed to be 0. Day-relative timestamps are most useful
    with anchors (see below).
    Timelines can also be anchored to their timestamps. When a timeline is anchored, then the
    timeline has a notion of "now" in timeline time, such that playback can be more or less
    synchronized for all users. For example, if a timeline is anchored to 3:00 MST and a user begins
    watching the timeline at 3:05 MST, starting playback with
    Play(-1)
    will result in playback
    starting at 5 minutes into the timeline. If another user begins watching at 3:10 MST, then
    Play(-1)
    will result in playback starting at 10 minutes into the timeline, and both users
    will be watching more or less the same point in the timeline.
    December 14, 2007
    Confidential
    Page
    29
    If a timeline is anchored using a day-relative timestamp, then playback happens more or less at
    the same local time for all users, regardless of where they are in the world. For example, a user
    in Los Angeles who views the timeline at 9 AM Pacific time will see the same content as a
    user in Washington D.C. who watches the timeline at 9 AM Eastern time.
    Playback of anchored timelines is similar to playback of truly live content—the duration
    grows over time and a user can seek to a "live" or "now" position that is not at time index 0.
    Likewise, if a user tries to seek beyond "now," the requested seek position will be moved
    backwards to the timeline's current "now" position. Note that this restriction should not be
    used to protect content that cannot legally be played until a certain time—a malicious user
    could modify the computer's local time into the future to circumvent this.
    Time-based, anchored timelines should be edited to remove the anchor property once it no
    longer makes sense. For example, if a timeline is anchored to Jan 1, 2005 and is only 24 hours
    long, it wouldn't make sense to have the timeline still anchored when Februrary 1st arrives (or
    January 2nd, for that matter). If a timeline is anchored using a fixed, time-based timestamp and a
    user tries to seek to the "live" position (via
    Play(-1)
    ), then playback begins at the very end
    of the timeline (so that either a
    MEDIAENDED
    playstate change will happen, or playback will
    move to the next timeline if a
    nextURL
    exists).
    The following illustrates a simple, day-relative (with a 30-second offset), anchored timeline:
    "clips":[{"url":"http://some/url/foo.qmx"}],
    "timestamp":"day,30,anchor"
    Anchored timelines can also have the wrap flag in the timestamp, which means that the start
    timestamp is adjusted if the initial point of playback is beyond the end of the anchored
    timeline. The net result is that it appears that the timeline looped (or wrapped around) over
    and over again up until now. Take, for example, a 3-hour timeline anchored to the start of the
    day. If a user tries to view the timeline at 8 AM, the timeline would already be "done" so there
    would be nothing to play. With wrapping turned on, however, the QVT library would notice
    this and behave as if the timeline repeated itself every 3 hours (the duration of the timeline), for
    example from midnight to 3AM, from 3AM to 6AM, and from 6AM to 9AM. Because 8AM falls
    into the 6–9AM timespan, the timeline would be anchored to 6AM and
    Play(-1)
    would
    result in playback starting 2 hours into the timeline (because the current time is 8AM and the
    timeline "started" at 6AM, or two hours ago).
    Wrapping results in the timeline anchor shifting as needed; it does not actually cause the
    timeline to play itself over and over. If the above timeline has a
    nextURL
    specified, then at
    9AM the next QVT would be loaded and playback would go from there. If you do want the
    timeline to actually play over and over again, then simply list its own URL as the next URL.
    For example, the following QVT effectively creates a virtual broadcast channel that does
    nothing but repeat an infomercial every hour (assume this timeline's URL is
    http://ww w.biff.com/foo.qvt):
    December 14, 2007
    Confidential
    Page
    30
    "clips":[{"url":"http://foo.com/hairloss.qmx",
    "range":"0,3600"}],
    "timestamp":"day,anchor,wrap",
    "next":"foo.qvt"
    If wrap is specified but anchor is not, the wrap flag is ignored. Note that it is valid to specify a
    timestamp in an external metadata file. Also, it is valid to specify a QVT-wide timestamp with
    just, for example,
    anchor,wrap
    —in this case the actual timestamp is assumed to be of type
    UTC and will be calculated based on one of the clips.
    The library makes many attempts to come up with a timeline timestamp. If no QVT-wide
    timestamp is specified, and no clips have an explicit timestamp set, and no clips are live, and
    no clips' QMX files are loaded for inspection, then the last clip's QMX is loaded and inspected
    in order to compute a timestamp of some sort. The only case in which a timeline may end up not
    having a timestamp is if all of the above are true and the last clip QMX cannot be loaded (bad
    URL, for example).
    If multiple clips in the timeline show up as live, all will be marked as non-live except for the
    last one. In this case, it is assumed that multiple live clips exist because earlier ones are from a
    crashed Atomizer or for some other reason a correct, final QMX was not published.
    MN.QVT
    attempts to use the clock times reported by Web servers (making the assumption that
    servers generally have more accurate clocks than end-user machines). It accomplishes this by
    inspecting the Date HTTP header when downloading QVT files. By using the server clock,
    MN.QVT
    has a better chance of making anchored timelines play back
  7. [quote:83bef46325="ronmiracle"]Yahoo! Search
    Help - Help for Webmasters
    « back to results for "how to play .qmx"
    Below is a cache of http://www.movenetworks.com/wp-content/uploads/movemediaplayersdk_20071214_01.pdf. It's a snapshot of the page taken as our search engine crawled the Web. We've highlighted the words: play playing qmx
    The web site itself may have changed. You can check the current page (without highlighting) or check for previous versions at the Internet Archive.
    Yahoo! is not affiliated with the authors of this page or responsible for its content.
    Move Media Player
    SDK Documentation
    December 14, 2007
    Confidential
    Page
    2
    Address
    796 East Utah Valley Drive
    American Fork, UT 84003
    General Information
    Phone: 801.216.8861
    Fax: 801.756.5806
    info@movenetworks.com
    Sales Information
    Phone: 801.216.8828
    Fax: 801.756.5806
    salesoffice@movenetworks.com
    Table of Contents
    Table of Contents .................................................. .................................................. ................................................ 2
    1 Overview .................................................. .................................................. .................................................. ......... 4
    2 Player Object Creation and Exposure.......................................... .................................................. ................ 4
    2.1 Code to Create Player............................................ .................................................. ...............4
    2.2 Code to Play a QVT or QMX............................................... .................................................5
    3 Player Installation and Version Upgrade .................................................. .................................................. . 6
    3.1 QMP Install Library........................................... .................................................. ..................6
    3.2 Supported Platforms .................................................. .................................................. ...........7
    3.3 QMP Install APIs .................................................. .................................................. ............ 10
    4 Player Communication, Manipulation, and Control .................................................. ..............................10
    4.1 Player APIs .................................................. .................................................. ....................... 10
    4.2 Player Events .................................................. .................................................. .................... 13
    4.3 Play States .................................................. .................................................. ......................... 16
    4.4 Player Settings.......................................... .................................................. .......................... 17
    5 Player Related Web Page Enrichment .................................................. .................................................. .....18
    5.1 My First Player Page Tutorial.......................................... ................................................. 18
    6 Quantum Virtual Timelines (QVT)............................................. .................................................. .................21
    6.1 Introduction to QVT............................................... .................................................. ........... 21
    6.2 Shows versus Clips versus Gap Clips .................................................. .......................... 22
    6.3 QVT Objects........................................... .................................................. ............................. 22
    6.4 Open-ended Timelines .................................................. .................................................. .... 25
    6.5 QVT JSON File Format............................................ .................................................. .......... 25
    6.6 Timestamps and Anchors........................................... .................................................. ....... 28
    6.7 External Metadata.......................................... .................................................. ..................... 30
    December 14, 2007
    Confidential
    Page
    3
    6.8 Miscellaneous .................................................. .................................................. ................... 32
    7 Helper Objects, Methods and Functions, and Debugging......................................... ............................32
    7.1 Importing/Loading Libraries .................................................. .......................................... 32
    7.2 String Functions......................................... .................................................. ........................ 33
    7.3 Utility Functions .................................................. .................................................. ............. 33
    7.4 URL Functions......................................... .................................................. .......................... 35
    7.5 Logging Functionality .................................................. .................................................. ... 36
    December 14, 2007
    Confidential
    Page
    4
    1 Overview
    The Move Networks Video Player SDK is a Javascript-based library containing several
    different types of functionality, all accessible remotely from a Web server via a Web page.
    HTML pages exposing the Move Networks Media Player (QMP) use QVT and related services
    to access and manage the player, hiding complexity and increasing the cross platform
    compatibility of the page.
    In order to a get a player, the page must load the QVT library (
    qvt.js
    ) with the help of the
    Move Networks library (
    movenetworks.js
    Include the QVT library by way of
    movenetworks.js
    with an import of
    qvt
    <script type="text/javascript" charset="utf-8" src="
    http://mvnet.xlontech.net/qm/move/stable/movenetworks.js
    " import="qvt"></script>
    Once loaded, your Web page will have access to the
    MN.QVT
    and
    MN.QVT.QVT
    objects, and
    thus the player object. Use one of the following APIs to create and expose the player.
    Two API options exist for creating a player:
    CreatePlayer()
    and
    EmitObj()
    . The only
    difference between the two is that
    CreatePlayer()
    is essentially a wrapper around
    EmitObj()
    that also attempts to install or upgrade a player prior to calling
    EmitObj()
    . It is
    recommended that
    CreatePlayer()
    be used in “production” player Web pages, since
    CreatePlayer()
    attempts to ensure that the player software is available before calling
    EmitObj()
    MN.QVT.CreatePlayer(parentID, callbackFunction, width, height)
    This API first attempts to install or upgrade a player. When the installation or upgrade is
    complete,
    EmitObj()
    is called. For example:
    <div id="playerParent">The player will go here</div>
    qmp = MN.QVT.CreatePlayer("playerParent", CallMeBack, 480,
    360);
    // now use qmp to control the player
    qmp.Play("http://www.foo.com/biff/baz.qvt");
    MN.Event.Observe( qmp, "PlayStateChanged",
    MyPlayStateChangedFunc );
    parentID
    : Can be either the parent ID or the parent object.
    December 14, 2007
    Confidential
    Page
    5
    callbackFunction
    : Function to be called after the player has been created. The
    parameter that will be passed to the
    callbackFunction
    depends on whether the
    player was successfully created or not. If successful, the player object will be passed.
    If not successful, a value of
    False
    will be passed.
    width
    : (optional) Width of the player in pixels. Defaults to 480.
    height
    : (optional) Height of the player in pixels. Defaults to 360.
    MN.QVT.EmitObj(parentID, width, height)
    The
    EmitObj()
    API is used to create a player instance in the
    parentID
    element without
    checking to see if the player software has been installed. This newly-created player object is
    then returned to the code. Caution should be taken when using the
    EmitObj()
    API because
    errors will occur if the player software has not been installed for use with the user’s browser.
    For example:
    qmp = MN.QVT.EmitObj("playerParent", 480, 360);
    qmp.Play("http://www.foo.com/biff/baz.qmx");
    Note: In the two examples above, either a normal QVT or a QMX URL can be used in the call
    to
    Play
    ; internally, the player converts QMX URLs to a virtual timeline with just a single
    piece of content. See the “QVT Objects” section below for more information.
    parentID
    width
    height
    Play(URL, start=-1, stop=0)
    Once a player object is available, you can play content using the
    Play()
    API.
    Play
    can be
    told to play a .qmx URL, a .qvt URL, a QVT object instance, or a QVT instance as a string. If
    null is passed in instead of a URL, the player’s current QVT object is used rather than loading
    a new one.
    Play()
    can also take an optional start and stop position. If -1 is passed as the starting
    position, an attempt is made to begin play at the most appropriate location. Omitting the stop
    position in a call to
    Play
    results in playing to the end.
    360);
    qmp.Play("http://www.foo.com/biff/baz.qvt", -1);
    December 14, 2007
    Confidential
    Page
    6
    URL
    : Can be a .qmx URL, a .qvt URL, a QVT object instance, or a QVT instance as a
    string. If null is passed instead of a URL, the player’s current QVT object is used.
    Start
    : (optional) Position within the QVT where play should begin. If -1 is
    passed, an attempt is made to begin play at the most appropriate location. Defaults to
    -1.
    Stop
    : (optional) Position within the QVT where play should end. Defaults to the
    end of the QVT.
    Also see the “Creating a Page” tutorial for additional code examples.
    Player installation and upgrade is handled automatically when the
    CreatePlayer()
    API is
    used to instantiate a player. This API uses the QMPInstall library
    qmpinstall.js
    to
    attempt to install or upgrade the player software from across the Internet. Other methods of
    installing or upgrading a player are not available at this time.
    The QMPInstall library (
    qmpinstall.js
    ) handles all the work around installing and
    upgrading the media player in a user’s browser. This includes the initial installation,
    subsequent upgrades, and ongoing status notifications, such as alerting the user of errors
    during the installation.
    Once a call to create a player has been made using the
    CreatePlayer()
    API, the page will
    go through the four steps listed below.
    1.
    A platform check will occur, and the user will be informed if the operating system or
    browser is not supported.
    2.
    If the platform is supported but the user has not installed the player, the user will be
    guided through the installation process.
    3.
    If the platform is supported and the player is installed but out of date, the user will be
    guided through an upgrade process. If, after the upgrade, a restart of the browser is
    needed to load the new player object, the user will be notified.
    4.
    After initialization, the optional player-loaded
    callbackFunction
    (see
    MN.QVT.CreatePlayer()
    above) will be called.
    Note: Customization of these steps is not currently supported. For example, the ability to skip
    step #3 is not allowed.
    The
    callbackFunction
    must expect a single parameter. That parameter will be set to either
    the player object or to a false value. If the callback function is passed a false value, this means
    December 14, 2007
    Confidential
    Page
    7
    that the player was not created successfully. If a non-false value is passed to the callback
    function, the player was created successfully and is ready to play content.
    In the
    callbackFunction
    , you might do a check at the beginning of the function like this:
    function OnPlayerLoaded(player)
    if(!player)
    // There was a problem creating the player object
    return;
    // You could put other code here as well
    // Otherwise you are good to go
    player.Play(someURL);
    Currently, Move Networks Media Player supports the following platforms and browsers:
    Platforms
    Microsoft Windows 2000/XP/Vista
    Apple Macintosh OS X or later (both PPC and Intel)
    Browsers
    Microsoft Internet Explorer 5.5 or later
    Mozilla Firefox 1.5 or later (Windows and Mac)
    Safari 1.3.2 (build 321.5) or later
    The following settings allow the player to determine which platforms and browsers are
    allowed to access any media player experience. Simply set each variable to true or false before
    the call to create the player.
    MN.QMPInstall.allowMozilla
    MN.QMPInstall.allowMacPPC
    MN.QMPInstall.allowMacIntel
    MN.QMPInstall.allowMacSafari
    For Example,
    MN.QMPInstall.allowMacPPC = false;
    would not allow users with a
    PowerPC Macintosh to install the player.
    Install Messages
    The QMPInstall library has a number of messages that it uses during the installation process
    to notify the user of the current status of the installation. These messages are displayed in the
    container which was passed into the
    CreatePlayer()
    function. General styling of these
    messages can be achieved by styling via CSS. The SDK comes with a default set of styles in
    qmpinstall.css
    that pages can include if needed.
    The installation messages have default values but can be customized to fit a page’s need.
    (Please see below for a list of install messages.) To overwrite the values of these messages, set
    MN.QMPInstall.MSG_*
    . The message values should be overwritten after the page has
    December 14, 2007
    Confidential
    Page
    8
    loaded but before the call to create a player. These values can be set to HTML as well as
    JavaScript strings. For example:
    <body>
    <!—Style the messages that appear during the install
    process -->
    <div id=”playerContainer” style=”font:bold 12px Tahoma;
    color:#4D7CB2;”></div>
    </body>
    function OnPageLoaded()
    MN.QMPInstall.MSG_CANINSTALL = ‘
    You do not have the free
    player. Click the download button to install it!.</p> \
    <a href=”#~” onclick=”MN.QMPInstall.StartInstall();”>
    <img src=”install_button.jpg” border=”0”> </a></p>’
    // Call to create player
    This code would display the following if the
    QMPInstall
    library detected that the user
    needed to install the player:
    The following table includes the installation messages and when they will appear to the user:
    Message
    Meaning / When Presented
    MSG_BADOS
    The user is running an unsupported operating system. If
    the string
    %s
    is present in the message, it is replaced with
    a list of supported operating systems.
    MSG_BADBROWSER
    The operating system is supported but the current
    browser is not. If the string
    %s
    it is replaced with a list of supported browsers for the
    operating system.
    MSG_NEEDREINSTALL
    Used when it is necessary to force the end user to start all
    over with the installation process. This will happen
    when the client already on the machine doesn't support
    the kind of upgrade needed, or the attempted upgrade
    didn't work for some reason. This is commonly known as
    the "forced upgrade."
    December 14, 2007
    Confidential
    Page
    9
    MSG_NEEDUPGRADE
    The user has an old version of the player that must be
    upgraded, and the upgrade will be performed
    automatically. The message should include an HTML
    span with the ID
    _qmpUpgradeProgress
    to hold the
    progress messages. This is used when a new client is
    needed before playback can occur. This is commonly
    known as the "foreground upgrade."
    Note: There is also a “background upgrade” which has
    no message associated with it by nature of not bothering
    the end user.
    MSG_UPGRADING
    Displayed repeatedly throughout the upgrade progress.
    If the string
    %s
    is present in the message it is replaced
    with the current progress.
    MSG_UPGRADEFAILED
    An automatic upgrade could not be completed. If the
    string
    %s
    is present in the message, it is replaced with a
    reason for the failure if known.
    MSG_CANINSTALL
    The user does not have the player at all and must install
    it. To initiate the installation, the message should
    include a link that calls
    MSG_INSTALLING
    Displayed once
    StartInstall
    has been called. If the
    string
    %s
    is present in the message it is replaced with
    one of the installation messages below to provide
    additional platform-specific instructions.
    MSG_INSTALL_java
    A Java-based installation is being used; user should be
    instructed to trust or allow the Java applet.
    MSG_INSTALL_win_ie
    The user is on Windows running Internet Explorer and
    will be prompted to download and run an executable file
    MSG_INSTALL_win_mozilla
    The user is on Windows running Firefox and will be
    instructed to download and run an executable file to
    install the player.
    MSG_NEEDRESTART
    An upgrade completed, but the new version could not be
    loaded. The user needs to restart the browser in order to
    complete the upgrade.
    December 14, 2007
    Confidential
    Page
    10
    CanPlay()
    Returns true if the player is installed and up to date. Use this to determine if the user is able to
    view content.
    InstallRequired()
    Returns true if an installation of the player is needed to play content.
    UpgradeRequired()
    Returns true if an old version of the player is installed but requires an upgrade.
    4.1 Player APIs
    CurrentBitRate()
    Returns the bit rate of the most recently played streamlets, in Kbps.
    CurrentClip()
    Returns the index in the timeline of the currently playing clip.
    CurrentPlayState()
    Returns the current state of playback as an integer. Please refer to the “PlayState” section for
    more information.
    CurrentPosition(position)
    Sets the current position in playback. The position can be given in either seconds or a
    timestamp string. If called with no arguments, the current position in playback is returned. A
    start value of -1 instructs the player to determine where playback should begin. If position
    exceeds the duration, playback starts at or near the current end of the timeline. If the position is
    less than 0 and not -1, playback starts at the beginning of the timeline.
    CurrentQVT()
    Returns the current QVT object being played. Call this when the QVT object is needed
    temporarily; do not save a reference to the returned object. See section 6.3 for more
    information.
    Duration()
    Returns the duration of the timeline in seconds.
    Encrypted()
    Returns
    true
    if any of the content’s sub-streams are encrypted and require a key for playback.
    FillColor(color)
    Sets the background fill color of the player. Use HTML color strings (for example, #FFFFFF).
    GetCurrentURL()
    Returns the URL currently being played. If nothing is playing, an empty string is returned.
    December 14, 2007
    Confidential
    Page
    11
    GetSetting(name)
    Retrieves a player setting from the operating system’s registry. Returns an empty string if no
    value has been set with given name.
    HasAudio()
    Returns
    true
    if the content currently playing has an audio stream.
    HasVideo()
    Returns
    true
    if the content currently playing has a video stream.
    Height(height)
    Sets the player’s height. If called with no arguments, the current height of the player is
    returned.
    InGap()
    Returns
    true
    if the current position is inside a gap. See section 6.2 about gap clips.
    Live()
    Returns
    true
    if the current stream is live. A live stream is an open-ended timeline.
    Load(URL)
    Like
    Play
    , this method loads the given URL and causes a
    TimelineLoaded
    event to fire
    when loaded. Unlike
    Play
    , however, playback does not start automatically.
    MetadataByIndex(index)
    Retrieves the value of the metadata at the given index. Use
    MetadataCount
    to find the
    number of pieces of metadata attached to the current content.
    MetadataByName(name)
    Retrieves the metadata value associated with the given name. Returns an empty string if there
    are no metadata by that name.
    MetadataCount()
    Returns the number of pieces of public metadata attached to the current content.
    MetadataName(index)
    Retrieves the name of the metadata at the given index point. Use
    MetadataCount
    to find the
    Muted(true or false)
    When value is set to
    true
    , sound is muted during playback. If called with no arguments, the
    player’s current muted state is returned.
    Paused(true or false)
    true
    , playback is paused. If called with no arguments, the player’s
    current paused state is returned.
    Start playback of the given URL. URLs should end in a .
    qvt
    or .
    qmx
    extension. The start and
    stop parameters can be given in either seconds or a timestamp string (for example,
    December 14, 2007
    Confidential
    Page
    12
    05:12:25.123
    ). The start parameter is optional and defaults to
    -1
    . A start value of
    -1
    instructs the player to determine where playback should begin. For live content this is as
    close to “live” as possible. For non-live content, this is at the beginning of the content. Any
    non-zero start value seeks to that position before playback starts. If a stop value is given,
    playback stops at that point.
    Note: This method for setting the start time (URL with included start value) is more efficient
    than calling
    Play
    and then setting the
    CurrentPosition
    PlayClip(qmxURL, title=””, start=-1, stop=-1, playStartPos=-1)
    Plays a portion of a clip, restricting playback to the specified range. The
    title
    start
    stop
    and
    playStartPos
    parameters are optional. The
    start
    and
    stop
    parameters can be
    given in either seconds or a timestamp string.
    Saves a player setting to the operating system’s registry. Unknown settings are ignored.
    Please refer to the
    PlayerSettings
    section for more information on valid settings.
    RealAspectRatio()
    Returns the actual video windows aspect ratio of the current content as a number (width
    divided by height).
    RegistryVersion()
    Returns the version of the player currently installed, according to the registry.
    Set(variable, value)
    Assigns the given value to the given variable. For example:
    var myfunc = "qmp.Set('SelectStreams', '0, -1, -1, -1, -1,
    -1,-1,-1,-1,-1,-1,-1');";
    // assure that the amount of flags is equivalent to the
    // profile set in use
    myfunc += "qmp.Set('Commit', '1');";
    flash.external.ExternalInterface.call("eval", myfunc);
    SetAutoPlayNext(value)
    When set to true, playback will advance to the next QVT when the current timeline is finished
    playing. If not set to false, will default to true and playback of the next QVT will occur
    automatically unless a playback stop position was given.
    SingleStep()
    When video playback is paused, calling this function will advance playback by one video
    frame, if possible.
    StartTimestamp()
    Returns the starting time of the current content in seconds since the epoch (January 1, 1970
    GMT). Use this to map content time to actual time. This function can be especially useful for
    getting the actual time for live content.
    Note: In JavaScript the
    Date
    object is in milliseconds.
    December 14, 2007
    Confidential
    Page
    13
    Stop()
    Stops playback. If nothing is playing, calling this has no effect.
    StopScrubbing()
    Stops scrubbing.
    UserAspectRatio(ratio)
    Sets the user-specified aspect ratio. This function is used to force the display to use a different
    aspect ratio. Calling with a ratio of 0 tells the player to use the real aspect ratio. If called with
    no arguments, the current user-specified aspect ratio is returned.
    Version()
    Returns the version of the player currently loaded in the browser.
    Note: The version and registry version values can be different.
    VideoHeight()
    Returns the video window height, in pixels, of the content currently playing. Returns zero if
    nothing is playing.
    VideoWidth()
    Returns the video window width, in pixels, of the content currently playing. Returns zero if
    nothing is playing.
    Volume(level)
    Sets the current volume level of the player, from 0 to 100 inclusive. If called with no
    arguments, the player’s current volume level is returned.
    Width(width)
    Sets the player’s width. If called with no arguments, the current width of the player is
    returned.
    4.2 Player Events
    AudioControl(muted, volume)
    Fired when the UI needs to be updated to reflect a change in the state of the audio controls. For
    example, after setting the Muted or Volume properties, this event will fire with the new values.
    The reason this is handled separately is that changes to the audio controls' state may occur
    outside the scope of the application (for example, the user clicks the Mute checkbox in the
    Wave column of the Windows Volume Control applet).
    BitmapReady(status, url)
    Fired when
    SendBitmapAsync
    or
    SendBitmap
    completes. The resulting status value is 0
    on failure and 1 on success with the URL parameter containing the URL of the uploaded file.
    Fired when the playback bit rate changes. The
    newRate
    parameter is the number of Kbps.
    Error(msg)
    Fired to pass an error message to the Web page (for example, a bad URL). The parameter is a
    human-readable string.
    December 14, 2007
    Confidential
    Page
    14
    MutedChanged(newMuted)
    Fired when the player’s muted state changes. The
    newMuted
    parameter is
    true
    if the player is
    muted.
    NextClip(clipNumber)
    Fired when the player transitions from one clip to the next in the timeline.
    NextTimeline(url)
    Fired when the player has finished playing the current timeline and is automatically moving to
    the next linked timeline.
    NotSustainable(reason)
    Fired for the lowest priority stream when any playing stream encounters too many frame drops.
    The player cancels the most recent not sustainable event when all streams go a period without
    a further frame drop. A reason code is returned.
    PausedChanged(newPaused)
    Fired when the player’s paused state changes. The
    newPaused
    parameter is
    true
    if playback
    is paused.
    PlayStateChanged(oldPlayState, newPlayState)
    Fired when the player transitions to a new play state. Please refer to the “P lay State Values”
    section for more information.
    Script(key, value)
    Fired when the player encounters an embedded script event. The key and value data are
    publisher-defined strings.
    ScrubBumper(atStart)
    Fired when a scrubbing operation has reached the beginning or end of the scrub range. Since
    scrubbing is currently only supported within the clip, and not across clips, the scrub range is
    the play range of the clip the user was in when they chose to begin scrubbing.
    ShowChanged(showNumber, showTitle)
    Fired when playback has moved to another item in the playlist.
    TimelineLoaded(qvt)
    Fired when the playlist for a timeline has finished loading.
    VolumeChanged(newVolume)
    Fired when the player’s volume has changed. The
    newVol
    parameter is the current value of the
    player’s volume from 0 to 100 inclusive.
    Event Handling
    The Move Networks SDK includes an event handling library. The event library extends the
    browser’s
    Event
    object to include functions for cross-browser event handling and player
    event handling.
    To add an event handler to an object, use the following:
    December 14, 2007
    Confidential
    Page
    15
    MN.Event.Observe(object, eventName, listenerFunction)
    For example, the following would set up a function to be called every time the player’s bit rate
    changed:
    function OnBitRateChanged(newRate)
    { // Function names can be anything of course
    log(‘The bit rate changed to ‘ + newRate + ‘ Kbps);
    MN.Event.Observe(playerObject or ID, ‘BitRateChanged’,
    OnBitRateChanged);
    Note: When using the event library, event names should not include the
    On
    prefix. (for
    example,
    onclick
    would be passed in as
    click
    To remove an event handler, use
    listenerFunction)
    For example, the following would stop observing the event that we started observing in the
    above example:
    MN.Event.StopObserving(playerObject, ‘BitRateChanged’,
    OnBitRateChanged)
    Note: In order to stop observing an event correctly, the exact same values must be passed into
    the
    StopObserving
    function that were passed into the
    Observe
    function. If the arguments
    don’t match, the event will continue to be observed, and observation of a different event may
    be stopped by accident.
    In addition to hiding browser-specific details, these event functions also make it possible to
    “ stack” multiple listeners for a single event. Stacking allows multiple functions to listen for
    the same event being fired by an object. When the object fires the event, all the functions
    listening for that object’s event are called.
    For example, the following would allow you to have two functions listening for the player’s
    PlayStateChanged
    event:
    MN.Event.Observe(playerObject,‘PlayStateChanged’, UpdateUI)
    OnPlayStateChanged)
    When the player fires the
    PlayStateChanged
    event, both the
    UpdateUI
    and
    OnPlayStateChanged
    functions are called.
    Note: When stacking event handlers, there is no guarantee as to which order the listening
    To ensure that event handlers aren’t accidentally overwritten, it’s generally preferable to use
    the above functions for any event handling where multiple handlers might be used. For
    December 14, 2007
    Confidential
    Page
    16
    example, instead of specifying the page load/unload event handlers in the BODY HTML tag
    (for example,
    <body onload=”…”
    ), they can be handled by observing the
    load
    event on the
    window object:
    MN.Event.Observe(window, “load”, MyLoadFunc)
    Please refer to the “Creating My First Page” tutorial to learn more.
    Add an event handler to the given object. The object parameter may either be the object or the
    object’s ID. The
    listenerFunction
    is called when the object fires the event.
    MN.Event.StopObserving(object, eventName, listenerFunction)
    Remove an event handler for the given object. The object parameter may either be the object or
    the object’s ID. If no match for the event handler is found for the given object, the call is
    ignored.
    MN.Event.RemoveAllObservers()
    Removes all event handlers registered through
    MN.Event.Observe
    4.3 Play States
    The current state of playback can be retrieved by calling the player’s
    CurrentPlayState
    function. The player’s
    PlayStateChanged
    event is fired whenever this state changes.
    Functions listening for this event will be passed both the old and new play states. The SDK
    library provides a play state helper to display the play state as a text string rather than as a
    numerical value. This object is referenced using
    MN.QMP.PS
    . For example:
    var state = player.CurrentPlayState();
    if (state = = MN.QMP.PS.ERROR)
    // do something with the error
    $(“playState”).innerHTML = “Current PlayState is “ +
    MN.QMP.PS[state];
    The strings returned by the play state helper are the names of the states (see table below). It is
    important to note that the play states returned by the player and SDK libraries are numbers
    and not text strings. The play state helper converts these values into descriptive text strings
    that can be displayed to the end user.
    When the player is first created, its state is
    Init (0)
    . Once the player receives the command
    to play content, the state switches to
    Opening (1).
    The progression of the play states
    during playback is usually something like:
    Opening > Authorizing > Loading > Playing > Media Ended.
    The
    Waiting
    state (255) does not normally need to be handled. If the player is in this state, it
    usually means that the publisher is not keeping up with the pace of playback. This happens
    when the publisher is late publishing additional content to an open-ended timeline.
    Play State
    Number
    Name
    Description
    December 14, 2007
    Confidential
    Page
    17
    0
    Init
    Initializing and creating player interface
    1
    Opening
    Opening video content
    2
    Loading
    Loading the first streamlets of the content
    3 Playing
    Playing
    content
    4
    Stopped
    Playback of content has stopped as a result of calling
    the player Stop function
    5
    MediaEnded
    The end of the current content has been reached
    6
    Error
    An error has occurred with the player
    7
    Stalled
    Playback of content has stalled
    8
    Authorizing
    The player is requesting the server for authorization to
    play content
    255 Waiting
    Content is late being published for open-ended
    timelines
    4.4 Player Settings
    Note: These settings work in the majority of cases. They are present primarily for
    testing purposes and should not be changed without prior consultation.
    The player has a few user-selectable settings that modify its behavior. See the “P layer APIs”
    section for more information on retrieving and modifying setting values.
    To change a setting simply call
    player.PutSetting(name, value)
    . For example:
    Player.PutSetting(“Renderer”, “dx”).
    To retrieve a setting call
    player.GetSetting(name)
    To change the setting to its default call
    PutSetting
    with an empty string value, for example
    PutSetting(“Renderer”, “”).
    Calling
    GetSetting()
    or any setting other than
    RendererDesc
    returns that value last
    requested, not the one in use. Use the value of
    RendererDesc
    for information about the
    renderer currently in use.
    Name
    Value
    Comments
    December 14, 2007
    Confidential
    Page
    18
    RendererUseOverlays
    yes,no
    This tells the renderer whether or not to attempt
    to use video overlays, if available. This setting is
    used only by DirectX renderer.
    RendererDesc
    (read-only)
    Retrieves a text description of the renderer in use.
    Renderer
    vfw dx
    Selects which renderer to attempt to use for
    video: dx (DirectX, the default), vfw selects the
    older Video For Windows renderer.
    AudioRenderer ds
    waveout
    Selects which audio renderer to attempt to use
    for audio:
    ds
    (DirectSound),
    waveout
    selects
    the WaveOut audio renderer.
    The Move Networks Video Player SDK supports the development of feature-rich player Web
    pages. The Web page enrichment features are found in the following files:
    autoplayer.js
    minimal.js
    playerui.js
    shinyred.js
    validate.js
    widget.js
    In order to have enriched pages, one must first have a basic page. This tutorial shows how to
    create such a page.
    This tutorial covers the basics of putting the Move Play Client into a Web page. The 40 lines
    of code for this tutorial can be found below, at the end of section 5.1. This tutorial will
    reference that code, giving examples with the corresponding line number(s). If you run into
    any problems, see the “Troubleshooting” section below.
    First you need to include the URL to the
    movenetworks.js
    file and import the
    qvt.js
    library (line 8). This
    <script>
    tag should go into the body of your page.
    <script language=”javascript”
    src=”http://www.foo.com/url/to/movenetworks.js”
    import=”qvt”></script>
    The QVT library aids in embedding the player into your Web page.
    December 14, 2007
    Confidential
    Page
    19
    Next add a script section to the body of your page to put the functionality to create and use the
    player (line 12).
    <script language=”javascript”>
    // Code will go here
    </script>
    Define a function to be called when the window
    load
    event is fired, and include a call to
    show the logging pane and log a message to it (lines 15–18) Then observe the window load
    event passing in this function (line 37).
    MN.Log.ShowPane(500);
    log(‘Page
    loaded’);
    MN.Event.Observe(window, ‘load’, OnPageLoaded);
    Open the page in a browser. If you see the logging page with your log message in it, you have
    successfully loaded the Move Networks Client SDK. Showing the logging pane (line 17) is
    not necessary but is a good idea to always have visible during development of a page.
    When creating a player, two things are needed to pass in to the
    CreatePlayer()
    API:
    1. An HTML container to put the player object in.
    2. A function to be called once the player has been created.
    Create a container to hold the player in the body of the page, and give it an ID (line 10).
    <div id=”myplayer”></div>
    Now define a function to be called once the player has been created (lines 22–35). This
    function should check to make sure the value passed to it is not false. If the value is false, this
    means that there was an error creating the player. You should also add a global variable to
    hold the player object so that it can be referenced when calling other functions (line 13).
    var qmp = null; // will hold the reference to the player
    object
    function OnPlayerLoaded(playerObject)
    if(!playerObject)
    logError(‘Failed to create the player’);
    return;
    else
    // the player was successfully created and you
    are good to go
    December 14, 2007
    Confidential
    Page
    20
    qmp
    playerObject;
    qmp.Play(‘http://qmedia.xlontech.net/100170/streamlets/ \
    themagicofflight_on2/output.qmx’); // Play some content
    You are now ready to create the player. To create the player, call
    MN.QVT.CreatePlayer(playerID, callbackFunction, width, height)
    (line
    19). Place this call in the
    OnPageLoaded
    function that you already set up. The
    MN.QVT.CreatePlayer
    function takes optional width and height parameters to set the
    player’s initial width and height.
    MN.QVT.CreatePlayer(“myplayer”, OnPlayerLoaded, 480, 360);
    That is it! When you open the page in a browser, you should see video playing. If you don ’t
    see video or are having problems, refer to the “Troubleshooting” section below.
    Note: Pages that use the Move Networks Client SDK should typically specify a
    DOCTYPE
    like this (see line 1):
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0
    Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-
    transitional.dtd">
    An example code listing:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html>
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-
    1">
    <title>Creating a player</title>
    </head>
    <body>
    src="http://qmedia.xlontech.net/100348/qm/latest/movenetworks.js"
    <div id="mplayer"></div>
    <script language="javascript">
    var qmp = null;
    log('Page Loaded');
    MN.QVT.CreatePlayer("myplayer", OnPlayerLoaded, 480, 360);
    if(!player)
    logError('Failed to create the player');
    return;
    else
    // You are good to go
    December 14, 2007
    Confidential
    Page
    21
    qmp = player;
    qmp.Play('http://qmedia.xlontech.net/100170/streamlets/themagiccofflight_o
    n2/output.qmx');
    MN.Event.Observe(window, 'load', OnPageLoaded);
    </script>
    </body>
    </html>
    QVT provides services which allow one or more content segments to be sequenced as a single
    virtual content timeline within a single QVT (stored in a file with the extension .
    qvt
    ). Like
    many elements of Web-based software, they are stored on the Web server but consumed by the
    Web client.
    When playing a QVT, the player tries to treat the entire timeline as a single piece of content.
    This means that when one clip in the timeline finishes, playback moves to the next clip in the
    timeline. Only when playback of all clips has finished does the player enter the
    MEDIAENDED
    playstate.
    QVT files are simply text files stored in Javascript Object Notation (JSON) format
    http://www.json.org/
    ), which makes them interoperate with different languages as well as
    XML, but without the downsides of XML (such as bloat and the relative difficulty of reading
    and writing XML).
    A JSON string is white-space agnostic and basically has the form of the following line:
    { property1:value1 ... , propertyN:valueN }
    where property has the form of a double-quoted string and value can be either a double-quoted
    string, a JSON string, or a list of JSON strings enclosed in brackets ( “[ ]”). Only double-
    quoted strings are legal in JSON. See
    http://ww w.json.org/
    for a more formal syntax
    specification.
    QMP now ships with a built-in JSON verifier to ensure that no harmful code is included in the
    QVT. The raw JSON text is evaluated to create a JavaScript object.
    QVT files can have links to next and previous timelines. If a QVT has a next-QVT link, when
    playback of the current timeline ends, the player can automatically move to the next timeline
    (controlled using the
    SetAutoPlayNext(true/false)
    API). When playback moves to
    the new timeline, internally a call to
    Play(newQVT, 0)
    is made. Note that if playback does
    not reach the end of the timeline (because a stop position was requested), then playback will
    not automatically move to the next timeline, regardless of whether or not Set
    AutoPlayNext
    is enabled.
    December 14, 2007
    Confidential
    Page
    22
    A QVT file is made up of a list of URLs that represent the various media clips to play as part of
    the timeline. Each clip, however, may be made up of several shows.
    For example, the clip itself could cover an entire day's worth of TV programming. Even though
    it is a single clip, many shows were played throughout the day, and each show needs its own
    metadata.
    If a clip covers multiple shows, the per-show metadata can be specified using the
    .shows
    property in a QVT file (see “QVT File Format” below for more info). Otherwise, the clip
    metadata will be treated as if it were show metadata and will be accessible accordingly.
    If a clip does not have a URL specified, it is considered a gap or filler space between clips. A
    Web page using QVT could choose to skip the gap or allow it to "play" (the video window is
    not updated while a gap is playing, so a Web page could display an alternate image during
    that time, for example). A gap clip should not have a list of shows, but it can have arbitrary
    metadata.
    Instead of having shows tied to clips, a top-level show list can be given instead. This list has
    the same format as clip-level show lists, but the shows map directly to timeline times
    regardless of where clips begin and end. This can be useful in situations where multiple clips
    correspond to a single show list (for example, if the Atomizer is set to record all day but is
    restarted halfway through).
    If a show list is longer than the timeline at the time the QVT is loaded, it is truncated to make it
    match the actual timeline duration. Shows that begin beyond the end of the timeline are
    ignored, and if a show lasts longer than the timeline it is shortened. If you are using live
    content (such that the timeline continues to grow), simply mark your QVT file as reloadable
    and over time the list of shows that is included will grow automatically.
    6.3 QVT Objects
    QVT Javascript objects are created from the contents of a .
    qvt
    file, a JavaScript string that
    mirrors the contents of a .
    qvt
    file, or from another QVT object. They are separate from player
    objects.
    A QVT object contains all the information about the contents of a timeline. You can create a
    QVT object by either telling the player to play a URL (and then calling
    player.CurrentQVT()
    ) or with
    MN.QVT.AcquireQVT(url or str)
    Because QVT objects may automatically reload themselves, an internal cache of current QVT
    objects is maintained to prevent multiple copies of the same QVT from overrunning the server
    with update requests. If you obtain direct access to a QVT object via
    MN.QVT.AcquireQVT
    you need to call
    MN.QVT.ReleaseQVT(qvt)
    when done with it to ensure the cache stays
    up to date. Failure to do this won't necessarily cause errors, but if a user views many QVT
    objects in a single session, not calling this function could leave a lot of them lying around
    even when you're no longer using them.
    QVT objects have the following APIs:
    ClipToTimeline(clipNum, clipPos)
    December 14, 2007
    Confidential
    Page
    23
    Given a clip number and position, returns an overall timeline time.
    DecRef()
    Decrements the reference count for this object. This should be called once for each call to
    IncRef
    Duration(showNum)
    Returns the duration of the specified show. If
    showNum
    is omitted, returns current duration of
    GetSource()
    Returns the URL (or other input) passed to the object constructor.
    GetTimelineNow()
    For anchored timelines, returns a value in timeline time (in seconds) that corresponds to right
    now. For unanchored timelines, returns 0.
    GetSummary()
    Makes a "snapshot" of the current QVT and returns it; useful for generating a graphical version
    of the timeline for presentation to the user. Returns an object with the following properties:
    .duration
    - the total duration of the timeline
    .live
    - the value of
    qvt.HaveAnyLive()
    .shows
    - an array of show objects. Each show has the following properties:
    .startTime
    - when the show starts, in timeline time
    .stopTime
    - when the show ends, in timeline time
    .duration
    - the duration of this show, in seconds
    .title
    - the title of this show, if any
    .showNum
    - the show number (0-based)
    .isGap
    - true if this show is a gap instead of a clip of content
    HaveAnyLive()
    Returns true if any clips are marked as live.
    IncRef()
    Increments the reference count for this object. Use this when you need to save a reference to a
    QVT object, for example:
    theQVT = qmp.CurrentQVT().IncRef();
    InitialLoadDone()
    Returns true if the first-time load of this QVT has finished.
    IsAnchored()
    Returns true if this timeline is anchored; see the “Timestamps and Anchors” section for more
    info.
    IsGap(showNum)
    Returns true if the given show is a gap.
    December 14, 2007
    Confidential
    Page
    24
    IsLoading()
    Returns true if an asynchronous load or reload of this QVT is underway.
    IsOpenEnded()
    Returns true if this QVT is open-ended; see the “Open-ended Timelines” section below for
    more information.
    IsValid()
    Returns true once the QVT is fully loaded and has valid clips.
    Metadata(name, showNum)
    Returns the metadata for the given name, if any. If
    showNum
    is omitted, returns the metadata
    value for the QVT itself. Both QVT objects and individual shows can have arbitrary metadata.
    NextURL()
    If this QVT has a reference to a "next" timeline, returns its URL. This is used for linking
    timelines together.
    PosToDatetime(pos)
    Returns a datetime object representing the given position in the timeline converted to
    broadcast time. The returned object has the following members: year, month, day, hour, minute,
    second, dow (for “day of week,” Sunday=0). For example, if the timeline starts at Feb 1, 2005 at
    9:00AM PST, then calling
    PosToDatetime(3602
    ) would return an object with members
    giving the time of 10:00:02 on Feb 1, 2005, regardless of the user's local timezone. If the
    timeline does not have a timezone set (for example,
    Timezone()
    returns null), the returned
    time will be in UTC. The month value is 1-based (Jan.=1, Feb.=2, etc.).
    PrevURL()
    If this QVT has a reference to a "previous" timeline, returns its URL.
    PrimaryURL()
    If the QVT object has a
    primaryQVTURL
    member, returns it. If not, returns the QVT URL used
    to create the object. If no URL was used (for example, if a JavaScript object was passed in to
    the constructor), returns a false value. This function exists to aid pages that need a more
    permanent URL when a temporary URL was used to initiate playback (for example, if the
    Atomizer produced a
    today.qvt
    file and the viewer uses the Send to a Friend feature. On the
    next day,
    today.qvt
    would point to the wrong day, so instead the Atomizer would include
    a primary URL, and the Web page would call this API to include the correct URL in the Send
    to a Friend email).
    ShowCount()
    Returns the number of shows in this timeline.
    StartDatetime()
    Returns a datetime object (see
    PosToDatetime
    , below) representing the date and time when
    this timeline starts, in broadcast time. If the timeline does not have a timezone set (for example,
    Timezone()
    returns null), the returned time will be in UTC.
    StartTime(showNum)
    Returns the start time of the specified show (show numbers are 0-based).
    December 14, 2007
    Confidential
    Page
    25
    StartTimestamp()
    Returns the timestamp value for the timeline, if it has one.
    StopTime(showNum)
    Returns the stop time of the specified show.
    TimelineToClip(pos)
    Given a time in the timeline, returns a position object.
    TimelineToShow(pos)
    Given a time in the timeline, returns a show number.
    Timezone()
    Returns the timezone value for this timeline, if one is specified; null otherwise.
    Title(showNum)
    Returns the title of the specified show, if any. If
    showNum
    is omitted, returns the title of the
    entire timeline.
    Note that
    MN.QVT.ReleaseQVT(x)
    and
    x.DecRef()
    are functionally equivalent, but for
    clarity you should use
    ReleaseQVT
    if you obtained the QVT via
    AcquireQVT
    and
    DecRef
    if you obtained it via
    IncRef
    QVT files with a
    .reload
    property are said to be open-ended, which means that the timeline
    is considered to be incomplete and will be edited additionally over time. Open-ended
    timelines allow publishers to modify the future sequence of clips, even if some users are always
    viewing the timeline.
    If you create an open-ended timeline, be sure to remove the
    .reload
    property once the
    timeline is finalized (once you intend to make no further changes) so that the timeline is no
    longer open-ended.
    If a user plays an open-ended timeline and reaches its end before additional clips have been
    added (or before the QVT file is edited to no longer be open-ended), playback will pause at the
    end of the timeline and the player will enter the
    WAITING
    playstate (255). Later, when an
    edited version of the timeline is published, playback will move to the next clip if new clips
    were added. If the timeline was edited to no longer be open-ended, the behavior will be the
    same as if the timeline wasn't open-ended to begin with.
    Note that editing the range of a clip in an open-ended timeline will not have any effect if the
    user is already playing that clip (that is, if a clip has the range 10–20, and you edit the range
    to 10–100 after someone has already started playing that clip, that user will still have
    playback stop at 20, even if the new version of the timeline is loaded before playback of the
    clip ends).
    The raw JSON text is evaluated to create a JavaScript object. QVT objects can have the
    following properties; all of them are optional except for
    .clips
    December 14, 2007
    Confidential
    Page
    26
    .title
    - A title for the entire timeline.
    .prev
    - A QVT URL pertaining to a timeline that precedes the current one sequentially.
    .next
    - A QVT URL pertaining to a timeline that immediately follows this one. If this member
    is present, the player will automatically begin playing the next QVT when it reaches the end of
    the current QVT.
    .reload
    - The number of seconds to wait before automatically reloading the QVT to see if it
    has been updated. Do not specify this parameter unless you actually intend to edit the timeline
    at some point. Because each reload puts additional load on the remote servers, avoid using too
    low an interval except in testing. Typically, you should not use an interval of less than 300 (5
    minutes). When the interval is reached, the QVT is asynchronously reloaded and a
    TimelineLoaded
    event is fired so that the application or Web page can recreate any visual
    representation of the timeline (since new shows may have been added). See also the “Open-
    ended Timelines” section above for more information.
    .metadata
    - A URL to a QVT file containing any metadata for this timeline. See the
    “ External Metadata” section below for more information.
    .timestamp
    - A timestamp value as a string. Typically consists of the type (UTC or day), a
    number representing the UTC time in seconds, or the offset relative to the start of the day.
    Optionally can include anchor and wrap flags. See “Timestamps and Anchors” for more
    information. If this member is not specified, a timestamp will be calculated based on the
    timestamps of the clips.
    .showsTimestamp
    - Like timestamp, except that its time specifies the point in time
    that corresponds to the beginning of the show list. If
    showsTimestamp
    is present, the
    QVT library will perform whatever work is necessary to ensure that the show line properly
    maps to the timeline. See “Timestamps and Anchors” for more information. At this time,
    only UTC timestamps are supported, so a valid use might look like
    showsTimestamp:utc,1144951329
    .timezone
    - The number of hours (as a floating point number) to add to a UTC time to derive
    broadcast time for this timeline. For example, for Mountain Daylight Time a QVT could include
    timezone:-6.0
    . If the timezone is set, then the QVT
    Timezone
    StartDatetime
    , and
    PosToDatetime
    APIs work as expected.
    .shows
    - A list of shows and show metadata (see information on clip-based shows below or
    the section “Shows versus Clips versus Gap Clips” above) for more information. A QVT
    should not have both a top-level show list and clip-level show lists. If both are present,
    however, the top-level list is used.
    .clips
    - An array of sub-objects, with each one corresponding to a media clip to play. Clip
    objects have the following properties:
    .url
    - A valid QMX URL to play. If not specified, this clip is considered a gap clip.
    .range
    (optional) - The portion of the media to play (for example:
    range:10,25
    would play from time index 10 to time index 25, and then the player would move on
    December 14, 2007
    Confidential
    Page
    27
    to the next clip). Partially specified ranges are allowed too (for example, "100," but
    they take longer to load because the QVT library will download and inspect the
    QMX file to discover its duration. Ranges without an end time are not allowed for
    gap clips; a gap clip without an end time is removed from the QVT.
    shows
    (optional) - A list of show metadata objects. Each object should have a
    .start
    property, that tells the start time, in seconds, of the show relative to the
    clip. Other properties can be added as custom metadata, although QVT will use the
    .title
    property if present. Gap clips should not have a show list.
    .timestamp
    - A timestamp value in seconds UTC. Used to explicitly set the
    timestamp value for a clip. If no QVT timestamp is present, or if it does not specify an
    offset value, this clip's timestamp will be used to calculate an overall timestamp. A
    live clip is automatically given a timestamp based on the QMX start timestamp after
    adjusting for the clip's range. If multiple clips have a timestamp specified, the first is
    used. Note that the timestamp value given maps to the start of the selected range.
    Other arbitrary properties are allowed as additional metadata; if a
    .title
    property is present
    it is accessible via the
    QVT.Title(i)
    API.
    Below is a sample QVT file:
    "title":"My first QVT file",
    "clips":
    {"url":"qsp://Cool/Travel/Hawaii/output.qmx",
    "range":"100,300",
    "shows":
    { "title": "Intro" },
    "start":50,
    "title":"History
    and
    Heritage" },
    "start":100,
    "title":"Activities
    and
    Attractions" },
    { "start":180, "title":"Outro" }
    {"range":"0,10", "title":"A ten second gap"},
    {"url":"http://whatever/pepsi/output.qmx",
    "biff":"freep",
    "title":"Thousand Hand Slap", "range":"9,"},
    "url":"qsp://junk/stuff/zackandcody/output.qmx",
    "title":"Ugh"}
    "next":"http://127.0.0.1/qvt/second.qvt",
    "timezone":-7.0,
    "author":"Dave"
    December 14, 2007
    Confidential
    Page
    28
    Note in the above example that both clips and the entire QVT can have arbitrary metadata, and
    that the range on a clip is completely optional. The first clip actually covers multiple distinct
    segments, so it provides
    .shows
    to list per-show metadata. Note that the show times are
    relative to the start of the clip, and that
    .start
    is optional for the first show (actually, even if
    you specify a start value, QVT will always set the first show's start time to 0). Note that in the
    last clip, the end is not specified; QVT will load the QMX file to determine its length, and then
    set the clip end time automatically. In the third clip, no range is specified, so the entire content
    will be played. Between the two clips is a 10-second gap.
    General purpose content management and QVT creation tools will soon be available. Until
    then, it can be helpful to use JavaScript's
    eval
    function to verify that a QVT is syntactically
    correct. For example, if you have the QVT string data in a variable called raw, you can verify
    that the QVT is valid with:
    var obj;
    eval("obj=" + raw);
    alert(obj.clips.length); // and/or inspect the result in
    other ways
    The most common mistake when creating a QVT by hand is using single quotes around keys
    and values. While valid JavaScript, it is not valid JSON—always use double quotes!
    A timeline can have an overall timestamp (reported by
    qvt.StartTimestamp()
    in seconds,
    UTC) that reflects when the timeline started in actual (real-world) time. This timestamp can be
    displayed to the user or used to sync to a non-QVT metadata source if needed, but note that a
    timeline is not required to have a timestamp at all. If a QVT-wide timestamp is specified, it is
    used. Otherwise, each clip is inspected for a timestamp property. The first one found will be
    used as the timestamp, after adjusting for the duration of the previous clips (in other words, if
    the timeline has clips A,B,C, and D, and C has a timestamp, then the timeline timestamp will be
    C.timestamp - (A.duration + B.duration)
    ). Note that live clips are automatically
    given timestamp properties because the QMX always gets loaded.
    Currently, two types of timestamps exist: explicit time-based and day-relative. Time-based
    timestamps are in seconds UTC and specified like
    utc,1137687669
    (meaning Jan 19, 2006
    9:21:09 MST). Day-relative timestamps make the timeline appear to start relative to the start of
    the day in the user's local timezone. Day-relative timestamps can also have an offset value
    telling how many seconds past the start of the day the timeline starts. For example,
    day,3600
    means the timeline should appear to start 3600 seconds after midnight, or 1 AM in the user's
    local time. If an offset is omitted, it is assumed to be 0. Day-relative timestamps are most useful
    with anchors (see below).
    Timelines can also be anchored to their timestamps. When a timeline is anchored, then the
    timeline has a notion of "now" in timeline time, such that playback can be more or less
    synchronized for all users. For example, if a timeline is anchored to 3:00 MST and a user begins
    watching the timeline at 3:05 MST, starting playback with
    Play(-1)
    will result in playback
    starting at 5 minutes into the timeline. If another user begins watching at 3:10 MST, then
    Play(-1)
    will result in playback starting at 10 minutes into the timeline, and both users
    will be watching more or less the same point in the timeline.
    December 14, 2007
    Confidential
    Page
    29
    If a timeline is anchored using a day-relative timestamp, then playback happens more or less at
    the same local time for all users, regardless of where they are in the world. For example, a user
    in Los Angeles who views the timeline at 9 AM Pacific time will see the same content as a
    user in Washington D.C. who watches the timeline at 9 AM Eastern time.
    Playback of anchored timelines is similar to playback of truly live content—the duration
    grows over time and a user can seek to a "live" or "now" position that is not at time index 0.
    Likewise, if a user tries to seek beyond "now," the requested seek position will be moved
    backwards to the timeline's current "now" position. Note that this restriction should not be
    used to protect content that cannot legally be played until a certain time—a malicious user
    could modify the computer's local time into the future to circumvent this.
    Time-based, anchored timelines should be edited to remove the anchor property once it no
    longer makes sense. For example, if a timeline is anchored to Jan 1, 2005 and is only 24 hours
    long, it wouldn't make sense to have the timeline still anchored when Februrary 1st arrives (or
    January 2nd, for that matter). If a timeline is anchored using a fixed, time-based timestamp and a
    user tries to seek to the "live" position (via
    Play(-1)
    ), then playback begins at the very end
    of the timeline (so that either a
    MEDIAENDED
    playstate change will happen, or playback will
    move to the next timeline if a
    nextURL
    exists).
    The following illustrates a simple, day-relative (with a 30-second offset), anchored timeline:
    "clips":[{"url":"http://some/url/foo.qmx"}],
    "timestamp":"day,30,anchor"
    Anchored timelines can also have the wrap flag in the timestamp, which means that the start
    timestamp is adjusted if the initial point of playback is beyond the end of the anchored
    timeline. The net result is that it appears that the timeline looped (or wrapped around) over
    and over again up until now. Take, for example, a 3-hour timeline anchored to the start of the
    day. If a user tries to view the timeline at 8 AM, the timeline would already be "done" so there
    would be nothing to play. With wrapping turned on, however, the QVT library would notice
    this and behave as if the timeline repeated itself every 3 hours (the duration of the timeline), for
    example from midnight to 3AM, from 3AM to 6AM, and from 6AM to 9AM. Because 8AM falls
    into the 6–9AM timespan, the timeline would be anchored to 6AM and
    Play(-1)
    would
    result in playback starting 2 hours into the timeline (because the current time is 8AM and the
    timeline "started" at 6AM, or two hours ago).
    Wrapping results in the timeline anchor shifting as needed; it does not actually cause the
    timeline to play itself over and over. If the above timeline has a
    nextURL
    specified, then at
    9AM the next QVT would be loaded and playback would go from there. If you do want the
    timeline to actually play over and over again, then simply list its own URL as the next URL.
    For example, the following QVT effectively creates a virtual broadcast channel that does
    nothing but repeat an infomercial every hour (assume this timeline's URL is
    http://ww w.biff.com/foo.qvt):
    December 14, 2007
    Confidential
    Page
    30
    "clips":[{"url":"http://foo.com/hairloss.qmx",
    "range":"0,3600"}],
    "timestamp":"day,anchor,wrap",
    "next":"foo.qvt"
    If wrap is specified but anchor is not, the wrap flag is ignored. Note that it is valid to specify a
    timestamp in an external metadata file. Also, it is valid to specify a QVT-wide timestamp with
    just, for example,
    anchor,wrap
    —in this case the actual timestamp is assumed to be of type
    UTC and will be calculated based on one of the clips.
    The library makes many attempts to come up with a timeline timestamp. If no QVT-wide
    timestamp is specified, and no clips have an explicit timestamp set, and no clips are live, and
    no clips' QMX files are loaded for inspection, then the last clip's QMX is loaded and inspected
    in order to compute a timestamp of some sort. The only case in which a timeline may end up not
    having a timestamp is if all of the above are true and the last clip QMX cannot be loaded (bad
    URL, for example).
    If multiple clips in the timeline show up as live, all will be marked as non-live except for the
    last one. In this case, it is assumed that multiple live clips exist because earlier ones are from a
    crashed Atomizer or for some other reason a correct, final QMX was not published.
    MN.QVT
    attempts to use the clock times reported by Web servers (making the assumption that
    servers generally have more accurate clocks than end-user machines). It accomplishes this by
    inspecting the Date HTTP header when downloading QVT files. By using the server clock,
    MN.QVT
    has a better chance of maki
