Hi,
Recently I uploaded sum videos to an online vdo hosting service. My original files were in AVI. I downloaded the FLV version from the site after uploading it just to see what settings they use to convert their vdos so then I can use the same settings. But I convert my avi files using the same settings the quality is not the same!! Their quality is much better! Here are the parameters they use:
Resolution: 426 x 320 px
Framerate: 12 fps
Bit rate: 140 KB/s
Audio: 22050Hz, 14 kb/s , Monophonic
I used Riva FLV encoder. I normally use SUPER but it doesn't have support for custom resolutions.
Any ideas where I'm going wrong?
There is no patch for ignorance...
Resolution, framerate and constant/average bitrate
do not say a word about how the video is compressed.
Easy-to-use format converters actually hide from the user
how complex the subject video encoding really is.
BTW, and AFAIK, Riva is just a GUI for the command-line program
ffmpeg.exe.
Best quality flv to avi conversion
By Johnbil in forum Video ConversionReplies: 4Last Post: 22nd Mar 2012, 20:05 -
FLV conversion...
By mjl1297 in forum Video ConversionReplies: 11Last Post: 11th Apr 2011, 11:48 -
Is there a better way flv conversion
By talx in forum Video ConversionReplies: 2Last Post: 1st Oct 2010, 12:10 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 23:09
