Hi guys
Im sure there was a guide somwhere here that reviews the different types of dvd creation software..I can't seem to find it though.
What it is. I'm looking for something that will convert most file types, also I would like to be able to create my own menus..adding background music etc.
I used to use a program that would allow moving menus and background menu music..but can't remember which it was?
Lastly. A guy I work with managed to fit all the Rocky movies on to 1 disc..which he said was 4.7GB's and would play in any dvd player. How does he do this? I mean which format is he converting to, etc?
Guys, any advice would be great![]()
Cheers
Kev
tmpgenc dvd author 3 is easy to use and supports many input formats.
You can fit several hours on a dvd if use lower video quality. -
Thanks very much, mate.
Going to install and try the trial now. The guides that have been writen look very helpful aswell. I may still get stuck though, so there might be more questions
No doubt, once I've managed to create my first dvd and become aware of the features..it should be easier second time around.
Thanks again
Kev
Well, I've just spent 3hrs authoring a dvd and had just started to create it..then my laptop decided to crash
I couldn't save as I went along either, as it's disabled in the trial version
The software looks pretty good though. Seems easy enough to use and looks like it has everything I need. I think I'm going to buy this anyways..so at least I can save as I go along.
Regarding the crash, I think it must be a memory problem. I either have faulty hardware or to many startup process' running at once. Saying that though, my spec isn't that bad..2.0GHz Core 2 Duo/2GB RAM..so I'm not sure really. First thing I'm going to do is uninstall Norton...it's crap, never finds anything with scans and just sits there hogging resources.
Well, I'm off to see how cheep I can get this software for
Cheers
Oh yeah. You know the main menu, can I create my own text heading and place it where I choose in this area? -
"Oh yeah. You know the main menu, can I create my own text heading and place it where I choose in this area?" Yes.
Movie Creation/Editing Software
By jtrousd in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2011, 00:12 -
Full motion menu creation software with templates?
By TVJunkieLI in forum Authoring (DVD)Replies: 2Last Post: 7th Apr 2011, 09:54 -
Wanting more info on video rendering and creation software
By spiralthinker in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2011, 14:51 -
Need Help Finding Camcorder & Software to Win Soul Mate Back
By gbooth in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2008, 14:25 -
Free DVD Creation Software that offers Long-play?
By andymc35 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2007, 16:42
