OK, I've searched and I can't find a simple answer. I tried with DVD Decrypter IFO mode but it didn't work correctly. I just want to demux DVD-video that I have into separate M2V and AC3 files. What program can I use to do this?
Maybe you didn't notice it, but DVD Decrypter can EASILY do this. In IFO mode, select your clip, then change tabs to the [Stream Processing] tab, click to Enable Stream Processing, then highlight the stream you want and click the [Demux] radio button. Do this separately and fully for each and every stream that you want to be demuxed.
Then start the decrypting...
That's it. Done this scores of times, never had any problems. You can even select only certain chapters or cells to be demuxed...
Demux a Dolby Surround 2.0 file into separate streams?
By Xoanon in forum AudioReplies: 27Last Post: 2nd Jul 2021, 09:21 -
Separate AVCHD video files for burning on DVD
By csh in forum Authoring (Blu-ray)Replies: 5Last Post: 13th Jan 2012, 02:01 -
How Do I Join M2V and AC3 Files?
By lovelylisa in forum Video ConversionReplies: 1Last Post: 6th Jun 2011, 18:13 -
after vob Demux the m2v and ac3 have duration difference
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2010, 02:45 -
Joining M2V & AC3 files for DVD burning, Subtitle creation sub position
By blue2 in forum Authoring (DVD)Replies: 15Last Post: 29th May 2007, 09:56
