I've been using Tmpge for some time. Now, it seems that when I use the mpeg tools included to cut the VCD mpg, I end up with a non-compliant mpg. Any suggestions?![]()
Hail to the king baby!
Try to use the Source Range function prior to encoding, and you could save yourslef alot of grief. See in Sefy's Newbie DVD ripping guid or Baldrick's DivX to VCD for a guide to it..
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
I have used both the MPEG Cut tool and the Source Range, they both work great, however like dinesh said, be sure that your default in the MPEG Tool CUt is set to MPEG-1 Video CD, I have split 50-75 large files and never had problems with any of burning with Nero as VCD1 & VCD2 some I have cut up to three files, depending on the movie....
Bud
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 22:55 -
[FR] Cutting TS Help Me Please
By KERNEL32 in forum EditingReplies: 5Last Post: 26th Feb 2010, 13:38 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 07:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 10:13
