Is there a way to do this with my ace program TPMGEnc DVD Author 3? The DVD I have is made from a VHS that's a 2 or 3 generation copy from the master VHS, and I want to make the DVD a little better looking without re-encoding to a lossy format.
And maybe at the same time fix the volume which is a little low. I am open to other programs, by the way.
You will have to re-encode to make any changes to the video. You can demux the audio, sweeten it, and remux it. I believe you can change the volume without re-encoding the audio but if you want to use any filter other than normalize you'll have to re-encode.
What format will make it lose the least amount of quality and what program do I use to convert it?
Info:
3.41 GB total filesize (my computer can't handle single files over 4 GB)
NTSC 4:3
8000 kbps video 29.97 fps
MPEG-2 Codec
384 kb/s AC3 audio
Correcting saturation, contrast, brightness, etc...
By takearushfan in forum RestorationReplies: 28Last Post: 21st Sep 2011, 22:32 -
How do I increase brightness/contrast on DVDR only have DVD to work with)
By sonicdeth in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2010, 11:44 -
Video editing of brightness and contrast?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 6th Feb 2008, 18:31 -
Change brightness, contrast, color, etc.
By JoeMuskie in forum EditingReplies: 4Last Post: 22nd Oct 2007, 22:26
