want to master magiciso because its a baddazz little app. i highly recommend it
so far i havent been able to:
-burn a +700BM iso onto (2) cd-r
-am i totally wrong about this can or cannot a iso be +700MB?
they can be any size?
anyone?
i appreciate it and yes i will gladly listen to OTHER means of doing the (2) cd-r if you have them
An ISO is a disc image - that is, an identical copy of the disc contents taken at a very low level. The resulting ISO file will be as large as the amount of data it contains. If it comes from a full 700MB CD, it will be 700MB. If it comes from a full DVD it will be 4.38 GB.
If you want to split the contents of a single 700MB ISO across two discs, you have to first extract the content, then work out you want to split it up, then burn. However, a single 700MB ISO will fit on a 700MB CD, so I don't understand why you want to split the file.Read my blog here.
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
File Format Not recognized - Using MagicISo/gBurner
By Teac23 in forum ComputerReplies: 4Last Post: 24th Jun 2009, 07:44 -
ISO to DVD burning?
By sufcdan in forum MacReplies: 8Last Post: 22nd Feb 2008, 14:42 -
Iso Burning problem.
By whendreamsweep in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2007, 11:24 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
