I bought a pack of Imation DVD-R 4.7GB MBI01RG40 16x
00 00 00 00 01 40 c1 fd 9e d8 52 00 02 85 0d 10 .....@....R.....
88 9a 80 00 03 4d 42 49 20 30 31 00 04 52 47 34 .....MBI 01..RG4
30 00 00 00 05 88 80 00 00 00 02 00 06 09 0d 13 0...............
Media color and text:
Silver Imation DVD-R / 16x 4.7GB, 2hr
UPC/EAN Code:
051122219795
and they don't work in my Nec 2500a or my old 1100
They work great in my 3550-a
I've used my 2500 and 1100 foever and they always burn anything I throw at them.
Nero tells me that the discs are illegal and DVD decrypter doesn't even recognize that there is a disk in the drive.
Why would this happen?
drink up....the world's about to end
The media id for those IMATION discs is considered crappy dvd media. You can try using the latest DVDFAB DECRYPTER to see if those discs can be read. The NEC 1100 & 2500 probably doesn't support that media id but there maybe a firmware update for those drives to support that media id.
When I started regularly using 16x media in my 2500A I found I had to upgrade the firmware to make it work. Some would burn, most would not. The upgrade fixed it. They won't burn at 16x, but they burn.
Personally I would not bother with the imation discs, upgrade or not.Read my blog here.
thanks I'll upgrade the firmware. Imation is crap but I was forced to use it while I wait for my usual tayo yudens from meritline,
Imation 4x DVD-RW problem?
By carbfrze in forum MediaReplies: 8Last Post: 11th Mar 2009, 16:31 -
NEC TV to Pioneer DVD not working well
By Prasanna in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2008, 05:19 -
TDK now Imation - updated 10-30
By BiggerJim in forum MediaReplies: 1Last Post: 29th Oct 2008, 17:21 -
Imation DVD Burner
By waituke in forum DVD & Blu-ray WritersReplies: 1Last Post: 17th Feb 2008, 16:34 -
MAJOR probs w/ my NEC 2500A
By candlelight in forum DVD & Blu-ray WritersReplies: 25Last Post: 5th Sep 2007, 15:19
