Does anyone have any tips on temporal and spatial filtering? My video capture device's software has settings for both. I understand it's used for capturing old, damaged videos. Can it perform similiar to a Time base corrector, where it may help clean up videos? Can anyone give me any tips on setting these?
The temporal setting goes from 0 to 255, and the spatial setting goes from 0 to 7. I have several very old, 20 year old tapes that i wanna capture to DVD. If it won't help, then i'll be purchasing a TBC soon. For now, i will give it a whirl.
Any help would be appreciated!
thanks
Cleaning up the pictures while recording require too much resources, this is good for a "watch only" purpose.
Maybe if you got a very strong cpu that'll work otherwise = lot of dropped frames
If you wanna clean up your tape you should do it after capturing the video
msu has a very good filter or there is "neat video" too (not free)
And to conlude: a tbc has nothing to do with such denoiser filter*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Agree with themaster. Those kinds of filters will soften your footage, quite a lot if you overdo it. Better to capture first so you have a source you can go back while you experiment with settings. I did a lot of fooling around with these kinds of filters before arriving at the conclusion that in most cases they weren't necessary.
Remember, what you see on a computer monitor is NOT what you will see on a TV with your finished project. Don't fall into the trap of adjusting video for your monitor unless you intend to watch the video on the computer ONLY.
temporal degrain
By unclescoob in forum RestorationReplies: 10Last Post: 3rd Mar 2012, 22:53 -
What is spatial domain?
By linnirae in forum EditingReplies: 2Last Post: 30th Aug 2011, 22:12 -
IVTC question - did they temporal smooth first?
By volswagn in forum Video ConversionReplies: 7Last Post: 3rd May 2010, 11:06 -
Help with avisynth filters, removing grain, dust or spatial noise
By greyfalcon in forum Newbie / General discussionsReplies: 1Last Post: 15th Mar 2010, 10:08 -
Temporal smoothing before/after shrinking frame?
By Gew in forum EditingReplies: 23Last Post: 28th Sep 2009, 19:26
