Results 1 to 11 of 11
  1. sorry, I searched but couldn't find...what direction (radial) is a DVD read? Is it from the inside out or the outside in? thanks
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Going out, middle to edge.
    Same as an LP.
    You can see a disk that's only half-full has been written only on the part near the centre.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Single layer discs read from the inside to the outside. Dual layer discs read from the inside to the outside, refocus the laser, then read back into the centre. This is for standard DVD Video.
    I seem to remember a data write strategy for +R discs that allows for outside to inside, but I may be making this up.
    Read my blog here.
  4. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    Originally Posted by AlanHK
    Same as an LP.
    Opposite from and LP, but the same as a CD.
    http://en.wikipedia.org/wiki/Gramophone_record
  5. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Same as an LP.
    I remember playing LPs edge to centre . You must have meant CDs.
  6. Member Cornucopia's Avatar
    Layer1 = Inner to Outer, Layer2 (if exists) = Inner to Outer for PTP (Parallel Track Path), or Outer to Inner for OTP (Opposite Track Path)
    With the best authoring/burning software, you have a choice depending upon the kind of material and the relative balance you give between Layer1 vs. Layer2 (where you can split etc). Most common is OTP.
    HDDVD, BD = same as DVD
    CD, LD = Layer 1 (Inner to Outer) style
    LP, 45, 78, 16 rpm records = Outer to Inner (except for a few rare old ones)
  7. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Same as an LP.
    Yeah. It's been a long time since I played an LP...
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Maybe you listened to a lot of Led Zep backwards
    Read my blog here.
  9. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Paul is dead.
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Pass the mighty waterfall
    Read my blog here.
  11. Member Cornucopia's Avatar
    "I buried Paul", "Turn me on, dead man"...
