hello, i have a question about video converting if somebody can help me:
i want to know how many bitrate should i put in video converting softwares when converting for example a mpeg1 file to divx to have that same video with the same original quality, to not have for example a unnecessary bigger divx file with the same quality. video converting softwares give us the ability to choose everything but i want to know if there is a relation like:
1 mpeg file (100kb/s) = x * 1 divx file (5O kb/s) the two having the same quality. with x a coefficient.
and thanks
No,
compressibillity is dependent on source video characteristics.
What you want is constant quant encoding.
gl -
Forget bitrates and use constant quality encoding. Pick the quality you want and the encoder will use whatever bitrate is needed at each and every frame to achieve that quality.
In Divx this is called "1-pass quality based" encoding. Try setting the Target Quantizer to 3. A lower quantizer will give higher quaility but it will be a waste with a VCD source (you'll only be preserving the MPEG artifacts better). 4 will be lower quality and you'll start noticing some degredation. -
thanks guys and sorry for all this time i was sick i got an accident, now im ok.
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 21:28 -
Does Converting MPEG1 2 MPEG 2 improve quality?
By purpleronnie in forum RestorationReplies: 10Last Post: 7th Aug 2009, 16:47 -
Problems converting from mp4 to mpeg1
By chukde in forum ffmpegX general discussionReplies: 2Last Post: 24th Feb 2009, 19:12 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
any tool for converting vob files to mpeg1?
By sumeshkri in forum DVD RippingReplies: 8Last Post: 18th Feb 2008, 23:22
