I happened to worked with my brother's Dell 3 year old laptop with 15" monitor. I could not change the display from 800x600. The desktop's icons and text are big. Any idea what caused this? I do not know if the video card is onboard. It just has many programs installed that it would be a hassle to use the restore disc. This weekend, I'll try to reinstall the video driver, if any and if I can, then run the spyware and anti-virus programs. Thanks.
that usually happens from a bad video driver. uninstall any trace if the old one and re install.. should be fine.
megui display resolution
By xxxThiefxxx in forum Video ConversionReplies: 2Last Post: 30th Apr 2012, 16:52 -
Laptop HP: No more display
By themaster1 in forum ComputerReplies: 20Last Post: 4th Jan 2011, 19:59 -
Need some hand-holding - Laptop to monitor display
By hyphenate in forum ComputerReplies: 4Last Post: 26th Jul 2009, 04:58 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2008, 23:56 -
How to display RGBHV video on a Laptop Computer
By Valinote in forum Capturing and VCRReplies: 4Last Post: 9th May 2007, 17:56
