hi there.
I know that it is really annoying when someone comes along and asks really simple questions on a forum, but i have looked all over the internet and all the information that is available is at a more advanced level than i am currently at.
My problem is (in my head) simple.
I have a movie on my PC. I want to burn it to DVD and play it on my DVD player.
I burned it in its original format which is just a normal windows media file, and it works on my really cheap £20 dvd player. But on my more expensive one it complains that it is a non supported format.
I have seen loads of stuff about converting..divx....codecs.... formats etc...
but nothing that is simple enough to say... "to make a DVD work on your DVD player, you need it to be X and to make it X you need to .........."
I know that it wont be as simple as clicking a few buttons, but I just need the basic starting points so I can look from there and work it out myself!
Any help would be much appreicated
Phil
You obviously haven't looked in the right places, as it is all over this site.
First place to look is the top left corner of this page - What is DVD. It will tell you what specifications you have to meet to create a DVD.
I would suggest you try FAVC or DVD Flick to encode your video file and author it ready for burning.Read my blog here.
Simple question about VLC resizing each episode while playing.
By Becki_Mason in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2009, 21:36 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Playing DVD on Vista - not as simple as it seems
By igorek in forum Newbie / General discussionsReplies: 5Last Post: 8th Dec 2008, 22:46 -
How do I set chapter points in an already authored DVD?
By midders in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2008, 17:57 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39
