Yo....I just have a small question..I was just wondering if it matters what the recording surface of the cd has to be to work as a vcd on one's dvd player....I tried blue surface cd's and they don't work then I tried the Memorex black cd's but they didn't work..so.does anybody have any advise on which colour cd's or types of cd's would work best on a dvd player as vcd's...my dvd player is a toshiba sd 2050.....thx for the help
dude you need to first create test Cds to check out whta surface and what cd your DVD toshiba will read ! Check out the DVD plyer compatibility disk list from this site. THe link is there on the front page itself.
Not all DVD players read CD-Rs. Some can read CD-RWs too. Many can read SVCDs also. Try using HP-CD R.
Use gold surface CDs (on the back). THere is 99% possibility that ur toshiba doesnt support CD-r disks. becoz CDs with the blue colour surface on the backside record layer should have maximum compatibility. as they sell the most.
if you write Cd-rws disks using any CD writer then do it and create a testing CD and pop it up into your toshiba player.
otherwise consult ur technician or the shop from which you bought. or contact the company or check its website.
OR buy a Sony or Philips DVD player. THey are known (but still check out)
to have maximum CD compatibility (even pirated CDs play well). This is because these are the two companies actively involved in setiing up VCD and DVD standards for the industry -
ibadk,
Give a little look in this web site at:
http://www.vcdhelp.com/dvdplayers.php?DVDname=toshiba+&Search=Search&list=0
Some Toshiba DVD Players do not play CD-R and/or CD-RW.
I don't know if your specifc model does.
Bye
Colour output question
By pijetro in forum DVD & Blu-ray PlayersReplies: 7Last Post: 29th Jul 2011, 06:35 -
Monitors and colour.
By dfgh11 in forum EditingReplies: 3Last Post: 6th Jan 2011, 10:44 -
Question About Colour Primaries In Cs5
By betonz in forum EditingReplies: 0Last Post: 21st Jul 2010, 20:03 -
Menu Colour
By sambat in forum Authoring (DVD)Replies: 0Last Post: 26th Apr 2010, 07:54 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
