I have an NEC dvd player/burner.
It says empty... but it's not.
It can't read mini (3 inch) dvd (dual-sided) (DVD-10?)... what do I do now?
Thanks.
	Where did your mini-DVDs come from? A camcorder?
 If so, they may have to be finalized before you are able to easily read them. The same applies if they came from a DVD recorder.
	Sorry, not familiar with that camcorder. But not finalizing a DVD is a common reason that a disc is not readable in a PC. More common with DVR machines. Stand by, other members should be able to give you better info. Or consult your camcorder manual.
  how are dual layer dvds read?By dblake2 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 6th Jul 2012, 12:51
  Double-Sided, Dual-Layer DVD media?By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03
  Dual-Layer Double-Sided DVD's turnover?By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23
  @^DVD-Roms wont Read Dual Layer^@By Varchasve in forum Newbie / General discussionsReplies: 13Last Post: 20th Sep 2007, 20:13
  How do I convert double sided dvd to dual layer dvd?By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
