Where do you get original blank cds or dvds from? I mean the dvds that don't have the brand name all over the disc as well as the inner plastic.
Can you record whatever it is straight onto it or is a more complicated process involved?
Results 1 to 10 of 10
How's My English?
No name blank media can be bought at some office retailers. But there is no name on the stuff because it probably isn't good enough quality to put their name on.
If you are willing to allow for the makers logo on the hub, these are fine http://meritline.stores.yahoo.net/ritek-ridata-16x-dvd-r-media-dvdr-blank-media-silver-matte.html
The firmware in your dvd/cd burner WILL care what brand you use, and it will take longer to record on cheap media. There are media (identity and speed) ratings embedded on the disc. It does not pay to use cheap blanks. -
Just checked my supply of Taiyo Yuden CDs and DVDs.
Both are blank, nothing printed on them, and were purchased online.
Don't remember where I bought them.
(I checked the codes, they are legit.. if you can believe the codes) -
ok thanks but i did not mean cheap brands. I meant like the dvds that you would see when you buy an original movie like the matrix and all you see on it is the matrix label which i'm guessing is printed thermally and on the plastic you see like shiny bar code or stripe along with just numbers. I am talking about those dvds.
I do not want to do a dvd and someone looks at it and say "oh he uses memorex or tdk".
How's My English? -
The hollywood dvds are pressed in a commercial machine. Not available for retail sales. You can buy blank dvdr with a printable label and buy a printer capable of printing directly to the disc to make a pretty good looking disc though.
Donadagohvi (Cherokee for "Until we meet again") -
You pay a pressing plant to make them for you. They are not anything like CD-R and DVD+/-R discs. They are actually stamped from a master that puts pits in a metal disc, whereas recordable discs use dye to simulate the pits in pressed discs.Originally Posted by wan2no
One of the best DVD blanks around for recordable use, IMO: http://www.rima.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=R&Product_Code=1736-1...ode=TAIYOYUDEN
They have no markings on the label side. If you want labels you would need a thermal printer.
Or use this one for inkjet printing: http://www.rima.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=R&Product_Code=1760-1...ode=TAIYOYUDEN
Ordered in lot's of 100, they are very reasonable in price. These were from http://www.rima.com/
The 8X seems to give the best results for most burners, but the 16X also works very well.
To have pressed discs made, it is fairly expensive and a somewhat involved process. There is usually a minimum order of at least 200 discs, all the same, or more commonly, 1000 or more. Not cheap.
so how good are those taiyo yuden dvds. Are they reliable like Memorex, TDK or Maxwell dvds?
How's My English? -
Those are pressed, not burnt. You need a million dollar pressing machine and a clean room. SeeOriginally Posted by wan2no
http://www.keyproduction.co.uk/BusinessServices/CDandDVDdetails.html
Better. Actually, the best.Originally Posted by wan2no -
agreed, this is exactly what you are looking for.Originally Posted by redwudzI am just a worthless liar,
I am just an imbecil
DVDRIP vs Original DVD
By Smith79 in forum DVD RippingReplies: 6Last Post: 1st Jan 2012, 00:50 -
original DVD subtitles Help
By cavusozkan in forum Authoring (DVD)Replies: 5Last Post: 29th May 2010, 15:18 -
Original DVD Menu
By cavusozkan in forum Authoring (DVD)Replies: 8Last Post: 17th Feb 2010, 21:54 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52 -
3D DVD Blank Discs
By tealmarlin in forum MediaReplies: 7Last Post: 24th Aug 2009, 17:03
