hey how do you slow down a clip i read the manual but could not find anything. maybe im just blind!![]()
That is possible.Originally Posted by romik91
The search button in Vegas' HELP section is a powerful tool. Maybe you should do a search using "slow" or "slow down." With that said, here's the quick and easy answer you're looking for:
With your video clip in the timeline,
1. right-click on the clip,
2. select "Insert/Remove Envelope,"
3. then select "Velocity"
This will insert a velocity envelope and a green "marker/line" will appear on your clip - which can be moved up or down depending on your speed preference.The more you know, the more there is to know... -
Another way is to simply hold either ctrl or shift (cant remember which) and drag the clip along the timeline which slows it down.
I should have said drag the end point of the clip along the timeline, not the whole clip.
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 18:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 06:56 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 11:00 -
Sony Vegas 9.0
By blecap in forum Video ConversionReplies: 36Last Post: 22nd Jul 2009, 01:21 -
Sony Vegas 7.0 to 8.0?
By bdr13278 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 21st Sep 2008, 21:58
