Hi,
I am trying to follow the guide at doom9 for converting from DVD to Xvid. I used DVD2AVI to make my .d2v file and this is how i did it along with the settings. File open my VOB's and here are the main settings.
Video--> Field Operation Forced Film
Video--> Color Space YUV
Audio--> Track Number 1
Audio--> Dolby Digital Decode and Downmix
Audio--> 48--> 44.1 Off
Help--> VFAPI Plugin checked
File save as project die_hard1.d2v
Go into GK open d2v at the bottom here is the error message i get:
File is not a valid d2v project, avi or avs file!
Why can't i load it is my question? Thank you everyone.
Results 1 to 13 of 13
Not sure why not use AutoGK for Xvid , but to each his own!...
In dgindex >tick"save project and demux video...start VirtualDubMPEG2 ,open
demuxed m2v and in audio setting tick "Browse for audio" source>save as Xvid avi.....
Edit: just noticed you want to use GK .....nevermind if you don't want to use VDMPEG2 either....." Who needs Google, my wife knows everything" -
I could use VDMpeg2 but i don't understand what you want me to do. Reading that sounds confusing.Originally Posted by t0nee1
Start Dgindex, go to File >open/add vob's you want converted, >"Save project and demux video" save and you'll have an .m2v file that you can open with VDM2....start VDM2 >open m2v that dgindex created> in audio setting "Browse to audio" that Dgindex created when you demuxed video ,in video setting, set video compression to Xvid mpeg4 and "Save as AVI "
Perhaps this guide will help...
http://www.bobsomers.com/articles/dvd-xvid-ac3/" Who needs Google, my wife knows everything" -
I figured it out but the news is i can not at all use VDMPEG2 because i get errors. I am using VDMod so i do have a question or questions. VDMod don't have an audio tab. When i encode using VDMod do i still have audio in my movie after the encoding of Xvid? If not, how can i get the audio back into the movie?Originally Posted by t0nee1
In VDMod go to streams >stream list>available streams >add audio that was created by Dgindex when you demuxed the video>right click audio stream and check "full processing">right click audio stream and click "compression"set compression or leave at "no compression" press Ok, and save ......
But do read the guide I posted,I'm sure it'll help...
t0nee1,Originally Posted by t0nee1
I am encoding it now as XviD without audio. Is it possible to add the audio in after encoding? Do i do the above steps after encoding and when i save just go save as and set it for all files and uncheck the job? -
Yes it is possible to add audio later, but if you follow the instructions you can
process both the video and audio at the same time......just add the audio stream to project before saving,using the method I described above.....
read this, scroll down to the audio part....
http://www.animemusicvideos.org/guides/avtech/amvappvdubmod.html" Who needs Google, my wife knows everything" -
Here is another question. When it comes time in stream list do i click "save as wav" Or do i click ok and then go to file save as?Originally Posted by t0nee1
If I gather correctly, you opened a video file with VirtualDUbMod, then added an audio stream. If you are happy with the audio codec used in the source (probably AC3 since your using a DVD as source) you don't have to do anything else with the audio. Just use File -> Save as AVI. The audio will be muxed in with the video.
If you want to convert the audio, right click on audio in the stream list and select Full Processing Mode. Then right click and select Compression... Select an audio codec (MP3?) and configure it the way you want. Then Save as AVI.
Error with Auto Gordian Knot 2.55
By Salvus in forum Video ConversionReplies: 1Last Post: 2nd Nov 2009, 07:51 -
Auto Gordian Knot Hidden Options Error
By Mabbage in forum DVD RippingReplies: 1Last Post: 18th Aug 2008, 15:59 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 12:56 -
using Gordian Knot
By ricmetal in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 15:20 -
"No adjustment is possible" error in Auto Gordian Knot
By rahul.never2far in forum Video ConversionReplies: 0Last Post: 20th Oct 2007, 09:40
