Hey when i try to convert from a .rmvb file to divx i get this problem can someone help me ?
Code:Encoding started on Thu Oct 4 18:38:54 CEST 2007 MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team Mac OSX static build for ffmpegX FIXME:Hardenabling SSE and SSE2 without detection CPU: Intel (Family: 6, Stepping: 8) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x182cea1e REAL file format detected. FAAD: compressed input bitrate missing, assuming 128kbit/s! Stream description: Audio Stream Stream mimetype: audio/x-pn-realaudio Stream description: Video Stream Stream mimetype: video/x-pn-realvideo Stream mimetype: logical-fileinfo VIDEO: [RV40] 640x320 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:11 fourcc:0x30345652 size:640x320 fps:25.00 ftime:=0.0400 ========================================================================== Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding) Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): no suitable image found. Did find: /Library/Application Support/ffmpegX/reallib/drvc.so: unknown file type, first eight bytes: 0x7F 0x45 0x4C 0x46 0x01 0x01 0x01 0x00 Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv4.so.6.0, 1): image not found atio: 16000->176400) Selected audio codec: [faad] afm: faad (FAAD AAC (MPEG-2/MPEG-4 Audio) decoder) ========================================================================== Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [scale w=640 h=320] ========================================================================== Opening video decoder: [realvid] RealVideo decoder Read the RealVideo section of the DOCS! VDecoder init failed :( ing video decoder: [realvid] RealVideo decoder Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder Selected video codec: [rv40mac] vfm: realvid (Mac OS X RealPlayer 9 RV40 decoder) ========================================================================== Forcing output fourcc to 58564944 [DIVX] MP3 audio selected VDec: vo config request - 608 x 256 (preferred colorspace: Planar I420) VDec: using Planar I420 as output csp (no 0) Movie-Aspect is 2.00:1 - prescaling to correct movie aspect.
a. Did you install the Intel Reallib binaries?
b. Did you try it with renaming your .rmvb file to .rm, to see if it works better that way?
yes i'm using the intel based and now i also tryed to rename and it's same thing.
I can preview it with mplayer works great.. when i tab info nothing happends..
It seems that the audio stream comes first. Did you try the "invert mapping" option ?
Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
pls. help: converting .rmvb files using ffmpegX
By Dolly in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2009, 14:32 -
problems converting rmvb files
By Kavelian in forum ffmpegX general discussionReplies: 13Last Post: 15th Jun 2008, 11:58 -
Converting RMV to avi an dplaying rmvb files
By konig in forum Video ConversionReplies: 5Last Post: 31st Oct 2007, 16:12 -
.Rmvb Converting/ Burning DVD problems.
By evan11567 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2007, 00:35 -
Need help converting SCM files to mpg or avi or rmvb or wmv
By US Guy in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 01:01
